Cooling....by seperate head and body.
Having fins parallel to the body of the light does offer some advantages. You could have a fan blow down the length of the ribs for much superior cooling.
I’m not sure how you’d machine it though. I don’t think you could do it on a lathe. It might be really expensive to machine.
Been thinking about it…
I thought about that and the only way is to machine it is to first lathe it and then vertically mill the fins. OR do the entire thing on a 5 axis CNC mill.
I open a thread to ask for some 3d rendering help.
Would be interesting to have vertical ribs going the entire length of the light. I think cooling would be quite good even with the fins not exposed except for an air intake at one end and exhaust ports at the other with a fan for air circulation.
I think I know what you are talking about. There would be just as good grip on it as checkering plus with far more surface area, better and faster cooling.
More heat is transfered from the lights body into your hand (liquid cooling) than from the lights body into air (air cooling).
Flashlights arnt a new thing, if vertical ribs worked better they would have been implemented by now. Seems to me like all vertical ribs would do is decrease the contact area between hand and light body decreasing the cooling ability of the light…
Not saying it won’t look BA, but it won’t work any better.
Also since you’ve brought up fans what’s your plan for water resistance? Fans, especially tiny ones die when submerged cause the force needed to move liquid is so much higher than air their little motors just instantly die regardless whether they’re IPX sealed or not. On the few forced air cooled lights now I believe the fans are usually designed to sense water egress and shut down immediately to prevent burning up the tiny little motors.
Not necessarily.
It’s dead easy to make horizontal fins on a lathe. Easy = cheap so not surprising they appear on many lights.
Also, I think the main advantage of horizontal fins is that a fan could blow along each fin providing much superior convection. A fan on horizontal fins isn’t as good since the fan’s blast would be deflected away from the light as soon as it hits the first fin. This is why most PC heatsinks use a series of radial fins with the fan blowing air down the length of each fin.
In a flashlight, I don’t think vertical fins offer any real advantage unless the light also uses a fan. And right now fans are specialty items found in very few flashlights.
There would be less heat transferred if the connection was ribs. There is less mass conducting the heat and that finned mass is now subject to faster cooling.
More expensive to make. It would require one more machining step. On the other hand, machining is relativly dirt cheap these days.
That’s why I started the thread. :slight_smile:
I spent an hour on Google trying to find something that looked like what I was thinking and nothing. So chances are nobody has made one.
You asked and answered the question.
The separate head can be machined with much more surface area for passive cooling. Cooling ribs not only on the sides but also underneath the head. The fan, if there is a fan, would add yet another level of better cooling.
The ribs running parallel, connecting to the body would decrease the amount of heat transfer. I don’t know what is the working temperature of leds and their boards, but I assume it’s far higher then what we can withstand.
Then there is also the benefit of not transferring heat to the batteries.
It’s an idea.
Bingo.
A smaller shop would not want to invest in a 5 axis mill. So the way to do it is to machine a solid block on a CNC lathe then finish it on a CNC mill. The CNC mill can do the fin design and put the ribs/fins on the back of the body.
If the flashlight company is doing their own machining, they probably have a CNC mill to do the end caps. That can also do the fin machining.
The idea from a machining perspective is doable.
There is also (Longitudinally finned tube) or Finned Aluminum Extrusions you could look at…
https://r.search.yahoo.com/\_ylt=AwrJ7KGJDGJcawcAgVtXNyoA;\_ylu=X3oDMTEydnViZGI1BGNvbG8DYmYxBHBvcwMyBHZ0aWQDQjY4ODFfMQRzZWMDc3I-/RV=2/RE=1549958409/RO=10/RU=https%3A%2F%2Fwww.alibaba.com%2Fshowroom%2Ffin-tube-round-aluminum.html/RK=2/RS=XEtvyLnLGyI3oCoQIH4NoguZZ98-
@Spartans have you seen the Imalent MS12?
That’s the first light that came to mind when reading your post as it has the fan and I guess what you could call vertical fins or cooling ribs.
Matt/vestureofblood has a thread with nice video about it HERE
BINGO! Exact same principle but I was thinking a more elegant open rib design. More of the ribs distinctly hold the head separately.
This is the image that was playing in my mind for the head support….
I’d imagine it’d be extruded Al, like a CPU’s cooling-fan heatsink.
Just bore out the middle afterward to run the wires.
It would be cast to be “fancy”. But it’s going to be far more expensive to make.
In China, aluminum is a bit more then a buck a pound (circa 2016). It’s always best to start from stock material, either round bar or tube stock.
Zn can be cast, and it’s lightweight. We had a local mfr who’d do cast-Zn molds for production parts (everything from gears to whole cases), and once the mold’s done, you can get (amortise) a pretty low cost per part.
No idea what kind of volumes They™ do for flashlights, whether 1,000s or 100,000s, so can’t say anything about the economy of making cast-Zn parts. Think Mg was supplanted by Al for most things except hard-drive parts where you don’t care about cost as long as it’s light.
It looks exactly like the Nitecore EC4 line of product.
Easily done on a 4-axis machine or turning center with live tooling and auto bar feed… unattended 24/7 no problems whatsoever.
A brushless motor fan would inherently be water-resistant; you just have to keep dirt and debris out of the bearings and rotor. And the electronics that drive the motor.
