Fireflies E07 preview
I have the gun gray XPL 5K w/purple aux and it is my goto shadowchaser.
I conversed with Jacky re:clear ano w/ice blue aux and matching switch leds.
No joy yet, butt I put my standing bid in for what would be a beautiful combo.
Anyone else want to bug him? (gently)
I have my 1 xpl clear ano and another 1 grey nichia on the way. But honestly if they start matching the aux power button with the lense I will be buying another. I like the pl47 but it looks really top heavy for a angle light, and I’m a angle light fanatic. :person_with_crown:
Hey guys does anyone happen to know which version of Anduril the SST-20 lights use? I know it uses the same build as the PL47 but is it the 219 reduced current version or the full current one?
I don’t think Fireflies uses the PL47-219 build at all. If I understand correctly, all PL47/E07 models use the regular PL47 build.
So just to be clear, even the 219b E07s run the regular version? Does that hold for the ROT66 as well?
The ROT66-219B uses the ROT66-219 firmware, because its driver has fewer 7135 chips.
I don’t actually know why it has fewer 7135 chips, because the 219B emitters could easily handle all 14 chips. But it does, so it needed different firmware to accommodate the different hardware.
My guess is that the reduced number of chips was done to make the NarsilM version regulate down to an appropriate level after it sensed an overheat condition. It may have been easier to take off a few chips than to modify the firmware to set a different step-down level. But that’s not relevant with Anduril, so it would probably be fine now to run the regular driver with the regular firmware on all versions of the ROT66.
Basically, the ROT66 builds are separated by the number of 7135 chips — 7 or 14 chips. It’s not really about the emitter type.
I see, I was under the impression that the turbo mode was limited on the 219 version as the low Vf of the Nichia would cause it to draw too much current and go blue.
The whole reason I’m asking is because I had an early NarsilM 219b ROT66 with no aux LEDs. Long story short it failed and Jacky sent me a replacement head, but not before they sold out of 219s, so I got a modern SST-20 replacement. Was wondering if I had to reflash before swapping out for the 219s, but it sounds like I don’t then! That saves me a lot of trouble.
Thanks TK for your helpful reply!
So mine heats up very slowly on turbo, which I am assuming is down to the poor thermal path/lack of thermal paste issue, so my question is what does this mean for the longevity of the flashlight, and should I therefore avoid turbo to make sure nothing overheats?
If you have the skills to do so, it’d probably be a good idea to pull out the MCPCB, file it down a bit, and put it back in with better thermal contact. Failing that, it’d probably be a good idea to limit the use of turbo, at least with the high-CRI emitters.
It sounds like the MCPCB is so thick that it can still handle heat reasonably well even with the air gap though… and I think the heat transfers to the driver through the power wires, so the driver activates turbo step-down early enough to generally keep things safe.
So, basically, just keep an eye out for a blue shift, and throttle it back hard if that ever happens. Or if you can, open it up to fix things. Be warned though, some of the work involved in that is somewhat delicate. It’s probably not a good first project, but someone with experience should be able to handle it pretty easily.
I’ve been trying to wade through this thread, but it seems like most of the recent posts are about DIY techniques people are using to fix faulty flashlights. Are the problems still ongoing, or have they been fixed in new production? Since FF offers DHL shipping, I would think that the delay from a new order to when its quality can be reported on isn’t going to be super long, like some of the other flashlights shipped by epacket only…right?
Fireflies has supposedly fixed the issue of an air gap under the star by adding a much thicker layer of thermal grease to their latest production run.
However, it is unknown whether that run has made it to market yet. To date, no BLF’er has reported getting a flashlight with the extra thermal grease.
Have there been any reports of issues or fixes for the PL47 or ROT66 — or have the issues been limited to this model only?
Oh well, sounds like it is one for the box of shame, where all the broken things go to die :slight_smile:
I have plenty of reliable flashlights and won’t miss it.
Or you can just use the light and ignore the “under the hood” issues. It will probably still work fine even without opening it up.
Grey nichia arrived today. Inside looks better, the aux outside wires are a different color. Optic leg still broken. Of course the tint is nice, but what really surprised me is how quick the nichia heats up on turbo. Feels twice as hot as the XPL HI 5000k when on the same amount of time. Both look bone dry through the holes in the board. I plan on swapping led boards in the lights and using the gray at work and clear ano for home shelf queen with the nichia leds. At that time I plan on addressing the thermal issue for both of them
Do the cooling fins on your grey unit have chamfered or sharp edges?
No.
Got my clear XPL HI 4000K yesterday and it looks great. Today I noticed one of the LED optics looked cloudy. Took the bezel and optic out and decided to see what the light looked like mule mode. Turned it on and ramped up and the double clicked into Turbo. About 2 seconds in turbo and SMOKE started rolling out out of the light. Immediately shut it down. Guess that is what turned the optic cloudy.
I’m sure it’s not supposed to do that.
Get a qtip and some alcohol and clean the LEDs.
It’s definitely not supposed to do that.
Did you see where the smoke was coming from? Was it coming from an LED or from the group of wires in the center leading to the driver?
