If you have the skills to do so, it’d probably be a good idea to pull out the MCPCB, file it down a bit, and put it back in with better thermal contact. Failing that, it’d probably be a good idea to limit the use of turbo, at least with the high-CRI emitters.
It sounds like the MCPCB is so thick that it can still handle heat reasonably well even with the air gap though… and I think the heat transfers to the driver through the power wires, so the driver activates turbo step-down early enough to generally keep things safe.
So, basically, just keep an eye out for a blue shift, and throttle it back hard if that ever happens. Or if you can, open it up to fix things. Be warned though, some of the work involved in that is somewhat delicate. It’s probably not a good first project, but someone with experience should be able to handle it pretty easily.
I’ve been trying to wade through this thread, but it seems like most of the recent posts are about DIY techniques people are using to fix faulty flashlights. Are the problems still ongoing, or have they been fixed in new production? Since FF offers DHL shipping, I would think that the delay from a new order to when its quality can be reported on isn’t going to be super long, like some of the other flashlights shipped by epacket only…right?
Grey nichia arrived today. Inside looks better, the aux outside wires are a different color. Optic leg still broken. Of course the tint is nice, but what really surprised me is how quick the nichia heats up on turbo. Feels twice as hot as the XPL HI 5000k when on the same amount of time. Both look bone dry through the holes in the board. I plan on swapping led boards in the lights and using the gray at work and clear ano for home shelf queen with the nichia leds. At that time I plan on addressing the thermal issue for both of them
Got my clear XPL HI 4000K yesterday and it looks great. Today I noticed one of the LED optics looked cloudy. Took the bezel and optic out and decided to see what the light looked like mule mode. Turned it on and ramped up and the double clicked into Turbo. About 2 seconds in turbo and SMOKE started rolling out out of the light. Immediately shut it down. Guess that is what turned the optic cloudy.
Tried to configure nichia to go as low as xpl, but it will not. On reds and browns is where this nichia pops. But the xpl really puts out this highest highs and lowest lows with a decent color tint
Under close examination I saw two extremely small black/ brown spots on one of the LEDs. Got a qtip and alcohol and cleaned them all and was able to remove those spots. Fired it back up and into Turbo and one little wisp of smoke then nothing else. Tried a couple more times and no more smoke. The alcohol also cleaned the optic. Guess a dirty LED was the cause.
How is the light able to keep the MCU controlled switch led’s on while turning the TIR AUX LED’s off? I’d guess in the low AUX LED mode there isn’t enough voltage to switch on the AUX board but there is enough to light the two directly controlled switch led’s? AFAIK they’re on the same circuit with no mechanism to actually control them independently.
Yes I realize 2 are on all the time but in lockout mode there is a aux LED setting which powers the MCU controlled switch LEDs (so all 4 switch led’s are on) yet the TIR LED’s are off.
How is this accomplished? Maybe that’s a Lexel question?
Edit I’ve answered my own question… The window in which the red led’s are on is so small its possible to totally miss it. What had happened was the voltage fell below the setpoint with the light running so when I shut it off and locked it out all AUX LED’s were being commanded on but the TIR boards voltage monitor was keeping them off so only the switch led’s (all 4 of them) were on.
Tl;Dr my battery was dead and I was over thinking it… Check the small things first!
Does anyone know of a way to get just an aux emitter board, of say, yellow/ red aux LEDs? Is that something Neal would be able to sell (since he seems to be the only person with alternate options, but I’m also sorta assuming that’s just all pre-stocked……
