I’ve been trying to wade through this thread, but it seems like most of the recent posts are about DIY techniques people are using to fix faulty flashlights. Are the problems still ongoing, or have they been fixed in new production? Since FF offers DHL shipping, I would think that the delay from a new order to when its quality can be reported on isn’t going to be super long, like some of the other flashlights shipped by epacket only…right?
Fireflies has supposedly fixed the issue of an air gap under the star by adding a much thicker layer of thermal grease to their latest production run.
However, it is unknown whether that run has made it to market yet. To date, no BLF’er has reported getting a flashlight with the extra thermal grease.
Have there been any reports of issues or fixes for the PL47 or ROT66 — or have the issues been limited to this model only?
Oh well, sounds like it is one for the box of shame, where all the broken things go to die
I have plenty of reliable flashlights and won’t miss it.
Or you can just use the light and ignore the “under the hood” issues. It will probably still work fine even without opening it up.
Grey nichia arrived today. Inside looks better, the aux outside wires are a different color. Optic leg still broken. Of course the tint is nice, but what really surprised me is how quick the nichia heats up on turbo. Feels twice as hot as the XPL HI 5000k when on the same amount of time. Both look bone dry through the holes in the board. I plan on swapping led boards in the lights and using the gray at work and clear ano for home shelf queen with the nichia leds. At that time I plan on addressing the thermal issue for both of them
Do the cooling fins on your grey unit have chamfered or sharp edges?
No.
Got my clear XPL HI 4000K yesterday and it looks great. Today I noticed one of the LED optics looked cloudy. Took the bezel and optic out and decided to see what the light looked like mule mode. Turned it on and ramped up and the double clicked into Turbo. About 2 seconds in turbo and SMOKE started rolling out out of the light. Immediately shut it down. Guess that is what turned the optic cloudy.
I’m sure it’s not supposed to do that.
Get a qtip and some alcohol and clean the LEDs.
It’s definitely not supposed to do that.
Did you see where the smoke was coming from? Was it coming from an LED or from the group of wires in the center leading to the driver?
Tried to configure nichia to go as low as xpl, but it will not. On reds and browns is where this nichia pops. But the xpl really puts out this highest highs and lowest lows with a decent color tint
Under close examination I saw two extremely small black/ brown spots on one of the LEDs. Got a qtip and alcohol and cleaned them all and was able to remove those spots. Fired it back up and into Turbo and one little wisp of smoke then nothing else. Tried a couple more times and no more smoke. The alcohol also cleaned the optic. Guess a dirty LED was the cause.
Thank for the tip.
How is the light able to keep the MCU controlled switch led’s on while turning the TIR AUX LED’s off? I’d guess in the low AUX LED mode there isn’t enough voltage to switch on the AUX board but there is enough to light the two directly controlled switch led’s? AFAIK they’re on the same circuit with no mechanism to actually control them independently.
2 are not wired to mcu.
Here are a few more measurements of three more E07 using Samsung 30T.
E07 SST-20 4000k, emitters swapped by Texas_Ace (different batch of SST-20): 4,845 lumens
E07 SST-20 4000k: 4,888 lumens
E07 XP-L HI 4000k v2 5A, heavily used: 6,465 lumens
I took more measurements and here are the lumen results for 4 different E07:
E07 XP-L HI 6500k - QSO VTC6A 6,681; 30T 6,983
E07 XP-L HI 5000k - QSO VTC6A 6,551; Vapcell VTC6A 6,379; 30T 6,733; Vapcell 40T 6,810
E07 XP-L HI 5000k - QSO VTC6A 6,586; Vapcell VTC6A 6,630; 30T 7,327; Vapcell 40T 7,017; QSO 40T 6,983; LG M50 5,353
E07 219B sw45k 9080 - Vapcell VTC6A 3,707; 30T 4,301 (quickly dropping); Vapcell 40T 3,741; NCR21700A button top 2,828; LG M50 3,233For some reason, I cannot reproduce the 7,570 lumen measurement again. The unit I measured 7,570 now only makes 7,357 lumens. Not sure if the emitters already degraded from me constantly blasting turbo or is it due to some other reason. I’m surprised the XP-L HI v3 6500k unit is not as bright as one of the XP-L HI v2 5000k unit.
I think the 40T is the ideal battery for the XP-L HI version. For the 219B version, I would think the NCR21700A recessed top with 15A would be the best battery but I don’t have a charger that can charge the recessed top and the soldered button top version adds an incredible amount of resistance. Otherwise the LG M50 is not bad for the 219B. The 40T might be pushing it too hard in the long run.
Also I really like the look of this light. The knurling and the very deep and functional heat fins look great. Most of the weight is in the head of the light where it is needed most for heat sinking. Jack said he designed the final prototype with super thick 8mm shelf. I couldn’t measure it but with the optics removed, it seems the shelf is probably not that thick but without removing the mcpcb and driver I can’t say for sure. But it did look like Fireflies listened to our request to increase surface area and mass in the head for better heat sinking and dissipation.
Machining quality is not as good as the Emisar series but not too bad. The clear anodizing version is OMG beautiful and a must have for anyone’s collection. Now I’m patiently waiting for a copper version.
One suggested improvement is to find or make an optic with larger TIR cups for more focused beam. There’s too much wasted space between the cups. Otherwise, I think the size of this optic can fit 10 cups and emitters for an even more amazing flooder good for 10k real OTF lumens.
Overall, this is the best pocketable EDC I’ve seen to date. It is also BY FAR the brightest single cell production flashlight in the world. It is twice as bright as the previous record holder, which is the Emisar D4S.
Yes I realize 2 are on all the time but in lockout mode there is a aux LED setting which powers the MCU controlled switch LEDs (so all 4 switch led’s are on) yet the TIR LED’s are off.
How is this accomplished? Maybe that’s a Lexel question?
Edit I’ve answered my own question… The window in which the red led’s are on is so small its possible to totally miss it. What had happened was the voltage fell below the setpoint with the light running so when I shut it off and locked it out all AUX LED’s were being commanded on but the TIR boards voltage monitor was keeping them off so only the switch led’s (all 4 of them) were on.
Tl;Dr my battery was dead and I was over thinking it… Check the small things first!
Does anyone know of a way to get just an aux emitter board, of say, yellow/ red aux LEDs? Is that something Neal would be able to sell (since he seems to be the only person with alternate options, but I’m also sorta assuming that’s just all pre-stocked……
Thanks
[quote=SKV89]
Is that cell safe with the SST-20 4000k emitter?
Neal told me he was just getting his lights from fireflies directly. I did see a post somewhere here for aux tir boards.
