Typically speaking, if you have two identical lights with one made of aluminum and one made of copper, you will get MORE time at max power with the copper. Itās been proven over and over again.
Just recently I remember someone (maybe Maukka?) measuring the Turbo temps on an Astrolux S43 (aluminum head) and S43S (copper head). Both lights draw a lot of amps. The S43 held Turbo for about 30 seconds and the S43S held Turbo for about 40 seconds. So copper does have its advantages, but itās up to each person to decide if they want it.
I agree that the weight and tarnishing of copper tends to make me want to avoid those lights, but thatās just me. Aluminum has the advantage on weight and cost and still handles heat pretty well.
Still, some people like these more unusual materials, even if they cost more, weigh more and maybe donāt conduct heat well. They are definitely nice for collecting.
Ps, Iāve never had a titanium light. If they do a titanium FW3 Iāll be curious about it.
My biggest problem with stainless steel is itās even heavier than copper. I donāt think Iād want an FW3A in my pocket that weighs nearly a pound.
Frankly, from a practical perspective in terms of weight, heat, and cost nothing beats aluminum. But if I want a bit more bling without making the light too heavy, Iād accept Titanium.
Youāre correct if youāre tailstanding the light over an integrating sphere. Copper can hold more heat than aluminum and also conducts it better than aluminum. A copper light in that situation will absolutely run longer at higher power than an aluminum light.
However, that test isnāt necessarily accurate for real-world usage, because it fails to take into account that most of the time when you use your light you will hold it in your hand. :smiling_imp:
Surprisingly, your hand can take a lot LESS heat than both copper and aluminum. It isnāt necessarily helpful to have a light that take take a lot more heat if it is being held in your hand, which cannot. Unless you donāt mind your hand looking like a baked chicken after using your light.
Upgrading your hand to be able to withstand more heat from an all-copper light is not easy and may require gloves ā¦ or cybernetic technology that doesnāt exist yet. :confounded:
No, itās not about ātaking more heatā. Both lights got up to the same temperature before stepping down.
When it comes to little powerhouse lights itās always nice to have NarsilM, RampingIOS or Anduril so that you can adjust the thermal stepdown yourself. Then you never have to worry about it getting too hot.
Have you ever actually tried holding a copper version of a light side-by-side with an aluminum version of the same light?
The copper feels much, MUCH hotter in the hand. This is because the copper is more efficient at pulling the heat away from the LEDs to the exterior of the light. Also, aluminum anodizing tends to insulate a bit more than bare aluminum or copper.
I can hold an aluminum Emisar D4 at full power for probably twice as long as I can hold my much heavier and dimmer Sinner Cypreus copper triple.
The thing about long signatures is ā- people quit seeing them after a while.
The brain filters out pointless repetition. Like hearing the same ad over and over.
Fortunately, thereās also software available here for that filtering http://budgetlightforum.com/comment/1300106
You know the two rules for civilization: donāt annoy people, and donāt be too easily annoyed.
I only have one copper light, an S43S, so I canāt directly compare anything.
Have you considered swapping the driver in your Sinner for one with Bistro or Guppydrv, etcā¦ so that you can manually set the temperature step down? That might make it nicer to use on Turbo.
Itās wierd that the Sinner is dimmer, yet heats up quicker. Does the Sinner draw less or more amps from the battery than the D4? Iām not very familiar with either of these lights.
This is why I put some CF on this, stops most of the copper smell transfering to hands, less tarnishing & buffers the heat a little on high output. (Plus I like the look)
My off the napkin and not necessarily correct calculations agree with Firelight2.
Copper gives better sustained performance but shorter turbos. Unless turbo is actually quite long, so better heat shedding helps.
The CRX way with carefully chosen insulation thickness (I think it should be quite thinā¦and too thin is better than too thick) can get the same thermal path from LED to skin as alu - and so the same LED temperature. However it will spread heat around the host better leading to higher sustained performance. Also turbo times should be much better than either alu or copper alone. More than 50% for sure.
I have 1 copper light and I EDC it nowadays.
Astrolux A1.
With a light this small the extra weight doesnāt matter every day. I also EDC Lumintop GT Mini (with a shorty tube). If that light was copper - no way I would carry it around.
I would love to have some larger copper host just for the sake of it but I wouldnāt use it very much.
In other news, still no newsā¦ sorry. CNY takes a while.
The FW3A proto4 is still working nicely, except for the issue already noted. I get occasional short+reboot errors when A) the parts go out of alignment, B) Iām holding the button, and C) itās using more than 1x7135 worth of power. Loosen/tighten the tube though, and itās happy again for another day or two.
So Iām hoping thatāll be taken care of. My proto2 unit doesnāt do this. Even with that issue though, I still find it nicer overall than most of my other lights.
It is 27mm x 25mm (1mm wall) 3K roll wrapped matt tube bonded to the copper with a very thin layer of JB Weld, something like 5-7 in plane, .5-.8 transverse for CF/ resin if that helps, I just know it takes the edge off
Ish. Not very well though. One can only do so much with a dremel. And to make things fit a little better I filed down the edges of the driver as far as they can go without making it not work any more, so thereās only a hair width of ground ring left. Itās not ideal.
In any case, my proto4 is now modified and no longer represents what to expect from a stock light. After CNY, I hope Lumintop will have some good news for us.
