[SALE] lighted TIR boards, D4, D4S, ROT66, MF01 multicolored with low battery waning and LVP
its meant to indirect light the white gasket
direct light version looks like this
I know, but why let it go to waste? The D1 doesn’t get that hot anyways I can make some holes, lol
edit; I mean in some cases they help cooling too…
Lexel - I's like to order a couple, maybe more, of these boards. I need one for my ROT66 (early version no AUX LED's), a D4, another quad, possibly an MF01, and possibly when you get the D1 ready. How does this work? pm you?
He will pm you for order details. Payment is through paypal.
Would this install in a D4 far surpass a newbies capacity? Super interested, but it might be a bit much to bite off.
It is not easy to install. The driver is hardly pressed in and there is verry less space for wires and soldering.
You will need a tiny wire for battery- on the aux-board. Battery+ is the same as LED+.
Usually most people do a reflash to D4S Firmware and use LED pin on driver for +
You could also flash Anduril for D4 with Aux support. D4S might work, but it’s not ideal as the part for the thermal regulation is made for a bigger part. Also the level mixing is off, as the D4S has more AMCs.
see here: How-To: D4 with Anduril + Aux support (windows)
But the whole process of installing (and flashing) is not a newbie task
So if I understand correctly, the LDO on the D4 TIR board causes it to have only one level of light? But if you took out the LDO then you could have low/high? I’ve never used aux lights before, so I’m basing it off of the H03 lexel driver with anduril, the light under the button has a few modes, high, low, flashing, off. Would this be the same with the stock D4 TIR board? Or would the LDO need removed? What are the implications of doing this?
I know I will need to flash the D4S firmware, or D4 anduril with the aux code added. But the LDO has confused me.
Sorry for all the questions, I want to learn, trying to understand.
Yes if you want high low then the LDO can be replaced with a resisor, which fits 0603 to get between the pads or build with resistors based on 3.7 not 2.8V
The LDO is to stabilize the current while battery voltage drops
Ok perfect, thanks Lexel!
Edit: any idea on when the D1S direct view TIR will be ready?
Edit 2: also, will building without LDO drastically increase current?
1. they are ready
2. you will need to use a resistor to get same brightness if you mod a board which was built with LDO, or it gets a lot brighter
Thank you for making these available, Lexel!
I am very interested in modding my D4 with an aux board.
I want the aux LEDs to act as a locator light, with a brightness roughly comparable to a large tritium vial. They shouldn’t light up a dark room.
I guess your “0.15mA” brightness level is most suitable for that?
Can I order a D4 board with a trimmer installed instead of an LDO so I can adjust current without soldering?
If yes, what is the approximate adjustment range for the “0.3mA” and “0.15mA” levels?
Problem with D4 board is it has no space for a regular 3x3mm trimmer
2x2mm trimmers may be possible to fit would need a new design and are pretty expensive so I never invested in that build
It is possible to replace the LDO carefully soldering with a resistor and you can use high/low feature with D4S Firmware to get on low tritium brightness
or just build at very low constant current with LDO
Ok, I had suspected that there isn’t enough space on the D4 board.
I will decide on the colors soon and place an order with you.
That is some amazing work.
Does the D4 board work with FF PL47?
Sent you a PM Lexel
I was doing now a full upgrade of D4S Aux board to rev. 3.1
I ordered Rev. 3.0 2 weeks ago, hope to test the new full battery indication
new:
- 3.9-4.2V additional outer ring (grren default) lights up in addition to main Aux LEDs
- Solder jumper to select classic unstabilized high/low LED level from Firmware or constant current with depleeting battery
- 2 indipendant Aux LED channels with trimmer reduced to one, so the full battery got a trimmer and fits 2 layer
- new indipendant voltage terminal
- reverse polarity protection
- standby drain when in LVP reduced from 40uA to 2uA
- smaller IC package to get additional space
- bigger markings of the trimmers
  • rounded component pads
right side rev. 1.1 compared with latest design on the left side
Nice changes. Having the middle open should help when connecting everything and you still managed to fit 5 more LEDs
