+1
Crap I bought it yesterday… any chance you could get an even better one than the current one for the MS12?
thats crazy “cheap” for that light
Hello my dear friends!
right after the CNY banggood.com releases the:
(click thelinks or pictures to go to the shop)
Astrolux FT03 ($45.95)
with Code: MVXBJ -> $ 28.99
SST40-W 2400lm 875m (190 kcd)
UI: NarsilM v1.3
USB-C Rechargeable 2A
26650 21700 18650 LED Flashlight
Battery: One 26650 cell (or a 21700/18650 cell) Cells are not included.
Driver: Texas Avenger FET Driver with charging
Reflector: High quality smooth reflector
Lens: Glass with anti-reflective coating
Body: Aluminum alloy with Type III hard-coat anodizing
Button: Silicone rubber
Ingress rating: Equivalent to IPX7, do not immerse in liquids
Impact resistance: Up to 1.5 meters
Weight: Approximately 295g without cells
Dimensions: 170mm*69.5mm*34.5 (length*head diameter*body diameter)
keeppower |
10.70 USD
use code AC18 ;)
a Bunker tour
veröffentlicht am 12. February 2019 in Allgemein von m4d m4x
here is a deal for the NEW
Convoy S2+ SST20
RA> 95 / 4000k
use this SHOPLINK and the code: BGCS2G to lower the price to US$ 12.99
Specification:
Brand | Convoy |
Material | Aluminum alloy |
Driver | 7135 biscotti firmware |
Low warning voltage | Yes |
Reverse polarity protection | Yes |
Lens type | Ar-coated glass |
Reflector | Soft |
Memory mode | Yes |
Tailstand | Yes |
Height | 118mm / 4.65inch |
Width | 241mm / 9.49inch |
Type | 7135 x 3 7135 x 4 7135 x 6 7135 x 8 |
Conductor | current output 1050mA current output 1400mA current output 2100mA current output 2800mA |
Weight | 76g |
Fasttech showed max lumens for the 8 chips at 650
I assume your refering to the sst20 output?
Yeah, it’s about the same or a little better than the Nichia 219B. Still noticable less than the XPG2, xpl or xml2, but maybe a nicer looking beam. I’m not too familiar with the sst20.
Of course.
The SST-20 4000k and below is a 2mm2 high CRI R9580 LED.
It is quite the LED.
Thanks! I ordered 4 of them…
reached 1111 Youtube subscribers!
so i ended the giveaway and did draw the winner:
No ways that’s me Suzuki Durban
Lol serious bro? I couldn’t make out the name he mentioned!
Super cool yeah it’s my company profile
Awesome! Congrats! Lucky bli#sem…
Thanks :money_mouth_face:
Hmmm…… I have tried to order the “NEW Convoy S2+ SST20” twice now, several hours apart. Each time it says: “The daily limit for this coupon has been reached. Please try again tomorrow.”
Is anyone else experiencing this??
worked fine here just now……
Thanks saypat… it worked fine for me this try also. :+1:
How many 7135 chips did you get on yours? I got 7135 x 8.
