Ish. Not very well though. One can only do so much with a dremel. And to make things fit a little better I filed down the edges of the driver as far as they can go without making it not work any more, so there’s only a hair width of ground ring left. It’s not ideal.
In any case, my proto4 is now modified and no longer represents what to expect from a stock light. After CNY, I hope Lumintop will have some good news for us.
Maybe the formulas aren’t the best way to judge it then.
When I first made the light I had a copper core & titanium outer shell but felt it was too much power not getting distributed through the metal, head area around the pill was scorching hot on turbo & rapid stepdown but the light was relatively cool elsewhere.
So I changed the shell to all copper but then the whole thing got too hot to handle while having a decent temp threshold (60°)
Then I tried the additional CF sleeve which made holding the light bearable though it still gets very hot.
Yes, lots of people looking forward to this one becoming available.
Remember you can send any of these protos to me to try to fix if you like :innocent:
That’s for someone with a 3D printer or an x-acto knife and some creativity to figure out. I’m not super serious with this suggestion but it does interest me, and since it’s from a real optics manufacturer I suspect it would diffuse better and have less impact on the tint of the beam than some of the other options I have seen.
Season it. Running it on turbo until just below the smoke point of the oil and holding it there forms a durable protective coating as the oil soaks into the pores of the cast iron and polymerizes. I do it with all of my cast iron lights.
My special FW3D #2 should be ready to pick up next week. It is gonna be a Brad Vice (Alabama Damascus) made from a billet of ’Alabama Buckshot Damascus’.
Pictures to follow if I can just figure out how to capture the images in that dream I just had.
Hello Teacher,
I’ve been having the same Dream about the FW3D- Raindrop and Alabama Buckshot Damascus Too! That is some Beautifully Crafted Damascus and it Really would make a Fine Looking FW3D Flashlight for Sure! Maybe even make One extra with 4 straight Flutes from the Tail Up to 1/8” from where the head or Optic seats and turn 3 small rings to Dispurse any Heat from the Front End? Etch it and that would be Absolutely Beautiful, just a Little Different then the Original Sleek Damascus Version of the Elegant FW3A Original I Dream of at least twice a week.
I sure look forward to getting That Sleek light in my hands when I am Awake, and not just Dreaming
Yeah, both those would make beautiful lights for sure!!
I’m acquainted with Brad Vice , their shop is less than 20 miles from my house.
I think I could get a proper sized billet from him fairly reasonably.
I have two friends that are machinist & teach that at two different vocational schools. One in my county & one in a neighboring county. They each have the latest equipment at their disposal.
When I actually get a FW3A in hand I am gonna disassemble one & take it to each of them to see what the possibility’s are. It sure can’t hurt.
Even if I had them change the internals a bit so as to eliminate the inner tube & electronic tailcap…. it would still be a beautiful light. .
All types of possibilities…… if I can get at least one of them on board.
