What did you mod today?
Just modded a laserpointer, better heatsinks and focus.
Also purchased another S2+ to mod later when it comes in.
Hey could you show a pic of the laser pointer?
What power level is it set at?
SX5 was a solid performer and seem to be built really well. I also like that it can run on multiple types of battery. But I haven’t used it for a while because of the emitter and not so nice beam. My modded H03 became my headlamp of choice. I was planning on leaving the driver as is and just replace the emitter and reflector. But the bright flash before going to moonlight mode really annoyed me so decided to replace the driver too. Now with the mod its my favorite work headlamp. I forgot how comfy and balanced it sits on the head with the separate battery pack.
A friend of mine has these on his truck, and asked me if I can get him some more “down-the-trail” range…
I used Carclo TIR lenses and XHP35 HI LEDs… made a new custom face out of some composite material I had laying around.
Google Photos
Google Photos
Obligatory beam shots… the stand of trees are about 170 yaards away.
Google Photos
Google Photos
Google Photos
I've been using this dual LED headlamp for a while now: https://www.aliexpress.com/item/XM-L2-Mini-Head-Lamp-Outdoor-White-Light-Headlamp.
I swapped the LED's to XM-L2 3D's for now, might be tuff to swap to decent MCPCB's, but cant get access to the driver yet - probably glued. This is a really decent cheap headlamp. The UI is not bad at all for my use, and it's light weight though the headstrap is a pain because it keeps loosening up, but better headstraps should work with it.
What driver and other changes did you make? I have a larger 6.5” model sitting here to mod
Those seem popular here and decent build quality especially considering the price. Nicron headlamps also seem to be nice candidates for headlamp host. I have their more expensive H30 which I modded. Its well built and stock output is good but UI is horrible (cycle to off). Modded mine to fet+1 and LH351D and it’s a nice throwy heeadlamp (21Kcd at turbo). Could increase throw with xpl-hi or sst-20s or White flat. I broke the driver though because of too much tinkering so now its sitting on my work bench.
Post #7000!
(at the moment)
I just made the new face plate to hold the Carclo optics, I believe 10048? Have to check my DigiKey receipts. The beamshot was hardwired into a 5200mAh 3s LiPo running the two XHP35s in parallel so a little over-driven, but I probably could run all 4 with it. Because the optic holder and MCPCB stick out past the original lens height I had to make a face plate with an integrated bezel for each TIR. I decided since I had only 1/2” stuff to make the bezel taller to add to the “projector” effect.
Haven’t decided on a driver yet, since I want to make sure I get one compatible for automotive use. But I want to incorporate either modes or ramping of some sort.
Look here: Q8 modding - #1556 by Wieselflinkpro
Received my black S2+ host and immediately proceeded to give it a bit of heat treatment before transplanting my Luxeon V triple into it. Makes the little hot rod look a bit more gnarly and hot rod-like!
D-C fix should have like 5-10% loss shouldnt it? Sphere never seems to react well when light is diffused at lens
That is worrying since the whole point of a sphere is integration.
I modded an old glass door knob & old pipe into a light .
I assume your setup is probably a bit more refined since you also do bare LEDs. Do you have a regulated light you can try with and without D-C Fix?
I do not own DC-fix. The method I use is frosting the glass with sand paper. But that would not measure the right thing I suppose.
RW, that’s amazing! Nice work! Love it when parts at hand are put to good use. :slight_smile:
Thanks , it was a learning experience . Hopefully the next thing will be a little better , I mean my efforts .
Today I have modified Skilhunt H03. Another with the rest. Previously I changed the diode on XP-L HI, now I changed the driver. The choice fell on Emisar (D1). I like the results very much. I have a ramp and a lot of power.
EagleEye X6
4x Luxeon V
Ledil Angie optic
MTN-17DDm
LED4Power spacer + mcpcb
Parts (with the giant hole I drilled in X6 shelf)
Spacer bolt (hollow for wires)
Spacer top side (bolted down)
Originally had everything wired up for a LD-B4 driver but I had issues and abandoned it. Here I demonstrate the art of wire stretchers to keep your mcpcb off your thermal paste while you solder your connections :slight_smile:
Abort, bypass this FET and lets go with what we have that works
Moon. Too bright w/ Luxeon V’s
I used two O rings cause i’m not sure the bezel applies enough pressure otherwise. I may try it with one and test heat transfer or try to find thicker glass.
