I too think that the S11 should be a 21700 flashlight, with the less than 7A that it draws there are no downsides switching to 21700 and only advantages.
Yeah, when the 21700 has most of the capacity of the 26650, and seems closer in size to the 18650 vs 26650, and has pretty good current ratings, as much as I like the 26650 I’d think the 21700 would be the better choice.
’Though all my 26650s here are now probably plotting to kill me for saying so.
I just received the S2+ in gray with the SST-20 emitter from Simon’s store. I really like the body color and beam the SST-20 creates. I ordered the light with 4 7135’s which allows the light to run at full power and not get uncomfortably hot. Simon, thanks for creating a great light.
Convoy S11
Will there be thermal control and brightness stabilization? Honestly, I had hopes for the S3 size (18650) for XHP50, but no one seems to be planning to do this besides zebralight (Zebralight SC600Fс IV Plus XHP50).
Can you make reverse clicky as an option for it? I think if people used to S2+ using method it is better to use same switch. If you worry about current I have no problems with reverse clicky switches up to 13A.
I like the look of that new S11, will definitely be purchasing one of those. 26650 and/or 21700 would be very nice. Either way, the plain cylinder shape is perfect.
