I calculated the switching frequency now and would even drop the inductor to 3.3uH
this gives me 550kHz switching frequency
with 33uH that thing would run on 5.5MHz no wonder it cookes like crazy
Thank you very much.
I will try it with a 3.3uH inductor and add input capacitor 3x10uF.
Shall I also add a 10uF capacitor accross the LED terminals? Or is it only optional? No calculation of it in the datasheet.
I also calculated the switching frequency according to the formula that can be found in the manual of the 16820 chip.
According to this, if you increase the inductivity the frequency gets lower.
And if you change the switching frequency in the calculator of maximintegrated the min. inductivity do not change.
I am not sure with low side switched buck, likely no caps across the LEds
Can you have a look at the modified design?
Would you suggest more modifications?
(R4 or R3 is optional, only for flexibility, different sizes and power)
I have just had time to build the modified driver.
With the modification you suggested the driver got cooler but it is still hot. Especially the FET.
driver
I connected it to an adjustable power supply and measured the followings:
Input 8.4V 4.16A >> 34.9W
LED 6V 5.04A >> 30.24W
So the efficiency is about 86%
I tried out what happens if I use it without cooling (the driver was not attached to any cooling plate, only the led).
The input current increased and when the efficiency decreased to about 83%, the fet got smooking hot and died.
In this case the driver should have dissipated ~6.5W
So I think that my driver less efficient and much hotter than it should be.
And one thing that is also strange, I ajusted the input voltage from 6 to 12 V. i thought that the led current should be constant. But is changed parallel to the input voltage.
I thought that a buck driver provide constant output if the input voltage is bigger than the led voltage.
Which FET do you use, sounds it has way too high switching losses
You need one with low gate charge, usual decent fast N-Mosfets have 4-7mOhms but only about 5-10nC total gate charge
Has this regulator a fixed switsching frequency or do you need to set it with a resistor?
It likely switches way too fast
The only way to see whats going on is using a decent digital memory oscilloscope
Also looked in the datasheet and according to it the buck has no low dropout, so its not allowed to drive 6V LED with 2S battery configuration
Increasing voltage should stay constant current so something is buggy
I use PSMN013-30MLC115 powerfet.
FET
13.6 mOhm RdsOn
8nC Qg
The XAL7070-332ME is only 3.3 uH, this is a mistake on my grawing.
XAL7070-332ME
The buck chip says regulating voltage is 200mV
So 21.5mOhm would get you 9A
How did you calculated this 21.5 mOhm?
I do not understand it, can you explain it?
It’s a simple omhs law calculation
I know that 200mV/21.5mOhm= 9.3A
How did we get the 21.5 mOhm?
You do the opposite:
0,200V/9A = 22,2mOhms.
OK. There is a misunderstanding.
There are 2 current sensing resistors on my drawing. Both of them are 43 mOhm. But I use only one of them. They have different sizes, I only have the option to use 1206 or 2512.Only for flexibility… And it is also written on the drawing, 1206 or 2512.
Lexel calculated the equivalant resistance of parallel resistors and he got 21.5 mOhm and from this 9A.
But the current should be only 200mV/43mOhm= 4.6A
But it could go higher and was not constant as I changed the input voltage.
If your output gets higher with more input voltage there is definately something wrong with the switching frequency or current sensing
the buck has to stay stable in output
I also see no 1uF directly connected to the buck input Vcc that is described in the datasheet
with 3.3uH I calculated 200kHz
also the driver design tool points more to 4.7uH
also too low input caps can cause a drop, but not a increase with voltage over the current that the sense resistor should give
also an output cap is possible to reduce noise
I have read the datasheet of the evaluation kit you linked.
Evaluation kit 16820
I can not see any differences between this and my schematics.
According to the datasheet, C1 and C3 are optional.
“Typically, capacitor C1 is not required if the power supply is relatively close to the EV kit. If long wires are used
to connect the power supply to the EV kit, install up to
10µF of bulk capacitance at the surface-mount 2220
pads provided for C1.”
“Typically, the LED ripple current equals the inductor ripple current. To reduce the LED ripple current, install
optional output capacitor C3. The EV kit provides surfacemount 0603 pads for a capacitor nominal value of 0.1µF.”
The input capacitor you did not see, is there. This is C4 1uF capacitor on my schematics.
I recalculated the design with Maximintegrated’s design tool:
Design tool
Changing the switching frequeny in the excel sheet does not really influence the L value calculated by it .
And you can also change the input voltage in quite a big range without influencing the L value.
The only new info I got from the eval kit datesheet is:
_To enter hysteretic mode, the following input requirements must be met: set VIN above 5V or above VFLED +
4V (whichever is greater), and provide 1.1A of input current to the EV kit. If low-voltage or low-current input conditions fail to meet the input requirements for hysteretic
mode, the MAX16820 controller operates in linear
mode providing DC current to the LED load._
The excel sheet does not have any warnings about it. According to it the design is feasible.
So I think it means that for a 6V led I need at least 6+4=10V input voltage. Othervise the driver will operates in linear mode. Most probably that is why my output current changed as I changed the input voltage. But if I make a simple calculation: 6V*4,8A=28,8W this is the power consumption of my XHP70. If I increase the input voltage to 10V, the input current would be around 2,8A.
If I increased the output voltage of my power supply over 7,4V (simulating a 2 cell lipo) the current was also increasing until my power supply limited it at around 5A.
So I still do not undertand what the problem is.
the tool say you only if the switching frequency is working or not
If you look on the switching frequency diagrams the linear mode is not included, this is why I guessed its not supportet, sure any buck will fall out of regulation at a point,
but as I pointed out its not a specified low dropout like the LM3409 which will fall out of regulation when the Input voltage is Output + losses, you said it right its likely 4V
I simply had not the time to read all datasheet but the diagrams tell me wehats going on on normal operation
At this point I would simply go with a lower shunt like 100mOhm to see if its working properly right there and which current you get with it
The XHP70 should use at 4.8A 6.6V, but also shunt resistor, MOSFET, PCB, MCPCB, Digital Multimeter and wires ect. increase the real voltage so this will be more like 31W
Power measurements are only valid if you use a clamp meter and measure the voltage over the driver oputput terminals not the LED board
Hi,
I still have problem with my design.
I also contacted maxim’s support and got the following answer:
_I tested on the EVKIT and changed 2 serial LEDs about 5V. When VIN is in the range 5V~20V, the LED current is basically stable and won’t go too high.
For the inductance, the formula V=L(di/dt). The inductance must be higher than the calculated value.
And also for the di, 1A LED current has about 0.3A di, 4.8A LED current has about 1.4A~1.5A di. But the EVKIT assembled 56uH inductor, so for sliding scale, 4.8A LED current also need a inductor bigger than 10uH._
I made a new driver with a 10uH inductor that was suggested by the support, but it did not work properly. The current is still not stable:
I also made some measuremets at the point indicated on the last picture of the link below:
https://imgur.com/a/hYBgiya
1. measurement at D2 at 25%pwm dimming signal
2. measurement at D2 at 50%pwm dimming signal
3. 4. and 5. measurement at D2 at 100%pwm dimming signal
My measurement (if it is correct) shows 3 MHz switching frequency?
Of course the driver is still to hot.
Shall I change to LM3409? Can it be better for my configuration (xhp 50 , xhp 70; 2 and 3 cell drivers)
on page 7 of the datasheet is written how the switching frequency can be calculated
if they sufggest delta I 1.5A, then with R=43mOhm you get 65mV Ripple voltage over the resistor
so calculating with Vin 3S 12V to Vout 7V
f sw=(12V-7V)*7V*0.043Ohm)/(12V*0.065V*0.0000047H)
I get with 4.7uH 410.5kHz switching frequency
Are you sure on your circuit no bad things happen like voltage spikes coming from your bench power supply
Had you run it on a battery pack?
