【convoy】H4 and B35AM options are updated
On the other hand, I love the reverse clicky mechanical switch of the S2+ and hope to see it back on one of the 21700 flashlights. And the bright colors of anodization too :slight_smile:
I’m very anxious to see the SST-40 and ramping driver, but SST40 is only cool white. I wish for warm tints. Hopefully it has a few useful mid-range currents (500, 800 mA) and not only fancy turbo.
Probably the ramping driver is suited for XML too, but more efficient than a 7135 Biscotti driver (Simon?). Then I can select the tints I like :slight_smile:
26650… someone didn’t do his homework.
S2+ 21700 quad: I’m in for it, should be a great fet host, however knurling of any kind would be welcome, it’s a flashlight, not a dildo. Plus diamond knurling sells simply because it has a sexy premium look and feel.
E-switches are the future. USB charging is a gimmick that unnecessary rises the production cost. But as Tom E stated it’s difficult to make a good e-switch. Emisar and Zebralight are examples of (very) good e-switches. Fireflies however is an example how it went horribly wrong. The switch on their lights is so small and so mushy it’s almost impossible to use the light wearing winter gloves.
It’s a shame no producer yet has made a e-switch, ramping, single emitter non-hotrod light, with boost/buck driver as premium option.
These blunt statements seem more like opinions to me than they appear.
Yep.
Tail switches have one massive advantage compared to e-switches:
No standby drain.
There are some other advantages too, but less apparent and more complex to implement.
Maybe the e-switch part, mechanical switches are of course a thing.
But look what happened to the immensely popular H03 which costed only 25-30$. It seems as if they don’t produce it any more in favour of the magnetic charging version which cost a whopping 45$, that’s a 15$ extra for inbuild charging while a decent budget charger cost maybe 3$ and a DIY lipo charging module 50 cents.
I’m thinking the S2+ 21700 would be good with regulated buck driver. We already have the Emisars, Fireflies, FW3A for the high output FET lights. This can be a very efficient practical use light.
+1 on a 21700 with a solid regulated buck driver.
High output FET is fun for to play with for a while, but high sustainable output is what I’m looking for. Something like 500 to 1,000 lumens without throttling back due to heat would be outstanding.
The part bout e-switches I probably said, or least was think'n, two years ago.
Our ATtiny designs still draw too much in parasitic drain, but if we turn off all the bling, the draw is so low, probably bout the same as leaving a cell in a power switch flashlight.
Hi Simon,
Where can I find the link at aliexpress to get it from you.Gotten a few S2+ and loving it. Do drop me email.
Here is the link to his AliExpress store. It shows a pic of it on the homepage but, it states “Coming Soon”. I think the Chinese New Year is winding down any day now so maybe it will show up for purchase soon.
BTW, I highly doubt he would email you from here, I could be totally wrong but, if you send him a message through his AliExpress store I am sure he will get back to you after the CNY.
https://convoy.aliexpress.com/store/330416?spm=2114.12010612.0.0.7ed3568a1CqkwD
BTW 2.0, I would remove your email address from your post. Might lead to a bit more spam than you bargained for.
i’m ready to design another S11 version with side e-switch and micro usb port ,too
it’s ramping driver,so you can set whatever brightness you like.
ready to produce S2+ 21700,
no big difference from S2+ 18650,
diameter 24-24.5mm , almost the same as S2+ 18650
,but a little longer .
the reflector and pill are the same
Are you going to do the same with the C8+? A 21700 cell tube with the same head
So the quad Carclo optics will not fit in the 21700 S2+?
C8+ powered by a 35-40A 21700 modded with a FET and led4power spacer + 6x MCPCB gives some possibilities :smiling_imp:
Simon, have you contacted Toykeeper about a ramping UI for that S11? I’m sure she can help you :wink:
Simon, I’m very happy with your plans for the S2+ 21700 :slight_smile:
For me it is the extra stamina from the bigger battery that counts. For more power, the C8 21700 is a good candidate, and the S11 is a very good looking new flashlight too!
Hope they’ll arrive soon before the daylight time is getting too long :wink: It feels like springtime in the Netherlands now (can still change any time though).
A convoy S2+ for 21700 and quad emitters would be nice but I would suggest the convoy S3 base body for this new 21700 because of its front stainless steel bezel, easier for swaping TIR lens. It also has a head shelf for the LED’s MCPCB (a bit less easier for swapping MCPCB than with a S2+ pill).
The S2+ is probably more versatile concerning the height of the MCPCB + TIR lens which is nice for modders.
As long as the head front opening doesn’t cover the LEDs front reflectors of the TIR, a triple/quad S2+ or S3 for 21700 is fine.
Compact 26650 and a boost driver! Me want this…
Hopefully no timed step down
- Clemence
I’m glad to hear about these new models.
C8 with a 21700 would be great!
I was expecting C8+ would have this feature.
