Oh, that is another geometric effect. The intensity vs angle graph in the datasheet is not the correct graph to integrate in order to get the total lumens. You have to also integrate as you rotate around the axis normal to the LED surface. Think about how all the light from an LED fills a half hemisphere. There is a lot more area and light at around 45 degrees compared to close to 0 degrees even though it is less intense. See here for discussion and a graph of the resulting light output vs angle.
I have it about nailed now. Speaking of full angles, the topmost 60° is (πr/3)² = (π²/9)r² volumetric area, which is just (100(π²/9)/2π)% = ≈17,4533% of the total half sphere volumetric area since a half sphere's area is 2πr². It now becomes clear why ≈25% of the light comes out of the topmost 60° cone.
Uuuugh! Some steam is coming out of my brain right now. :-D
This is what was literally explained in the beginning of this post I linked already.
You need to take into account area because there is more surface area on a hemisphere at larger angles.
A lux meter used to measure the intensity on the datasheet is kept at a constant 1m distance from the LED.
So the total luminous flux output of the LED is the integral of the candela over the whole hemisphere.
When flattened to 2d the result is the lobes graph:
Then you can take the area of one portion of the lobe to determine the fraction of lumens collected or lost.
I will have for the 1mm ² a CC FET soon,
maybe can drive at 7A with proper board layout and special cooling layout adding 0.5mm copper sheet and fill tons of viases with solder as well
sized are planned for 20,22 and 30mm, possibly also 17mm
for high current on CC FET regulation a proper heatsinking is needed, so I am massively enhancing the PCBs thermal properties with solder filled viases and copper sheet,
if there is enough interest and prototypes tested I may produce a 2 layer MCPCB driver (PCB cost for that is very high about 200$ for a bout 100 drivers)
I am not planning on using MOSLED for the FET cooling as this should work in as many hosts as possible
The surface area of said spherical cone comprises about 13.4% of the total surface area of the hemisphere, yet accounts for ~25% of the light. So ~75% of the light comes from the remaining ~86.6%. So if we “weighed” the luminous intensity coming from said 60 deg. cone, which is between .9-1 relative luminous intensity (I’ll guesstimate on average .96 at any point on that surface) and multiply that by .134 I get a result of .1286. Guesstimating the average luminous intensity of the remainder, using a typical chart, between 0 and .9, I’d say about .6. So multiplying .6 by .866 gives me .5196, which is just about 4 times the result I got from the top section. I’m sure the actual equation is a bit more complicated than this (and I hadn’t done calculus or differential equations in about 26 years) but intuitively it seems to jibe now.
It also makes sense why an RLT collar at 33% efficiency would potentially double the luminous intensity of the light coming out its aperture (given a 30 deg. half angle aperture).
While impractical, it also seems clear to me that given a luminous intensity chart for a given LED, there would be an optimal aperture angle for the RLT factoring in the luminous intensity graph, meaning there is an ideal focal length (ratio).
Of course now for a reflector, even a precision electroformed one with the most reflective coating is only approaching 90% efficiency, so that boosts the percentage of light from said 60 deg. cone to about 27% of total light output, and likely more given a typical flashlight reflector. Which makes me ponder that there is an “equilibrium angle” where the light coming from the top cone is equal to that of the lower section with the included efficiency factor. Not clear to me yet what use this would be of, but it should generate the most OTF lumens.
2) there is no optimal aperture, the more light that a wavien collar collects the less lumens are output and the more intense the light becomes.
For highest efficiency you use no collar, for highest candela/mm^2 you use a collar that covers almost 100% of the hemisphere.
60 degree opening was just chosen as a good middle ground by wavien.
3) silver coatings are 98, aluminum 90-95, and dielectric coatings can get to 99+
4) the highest OTF lumens are with a mule and no optic. For even highest efficiency, remove the front protection lens too, that will get another 1-3% light output.
1. I should pull out my old textbook… Just don’t have it in me right now.
2. There would be a aperture that gave the most output given a specific emitter. Basically best blend of distance and throw.
3. Yes I’m aware but those coatings are not typically used due to their fragiity. The “standard” coating with a good durability is rhodium which I believe is at around 90%. I’m sure the cast and milled ones we use typically are not as efficient.
4. Yes but we don’t buy White Flats to make mules…
Yeah, the only people using rhodium are the guys that make short arc flashlights because the UV degrades other coatings.
Protected aluminum is the standard coating for non-lamp applications, that’s what I bought.
Rhodium is also good if you like to clean you reflector with a cloth (for whatever reason) because it’s rather hard. You still need to be careful though.
Looks like Mountain Electronics has some Osram Flat White spacers for sale now. Still plan to buy Hoop’s because his are going to come with shim stock for adjusting the beam profile. Mountain Electronics may get me by for a while.
Heads up, the c8 style 30-30 gaskets I grabbed from mountain are for the smaller reflector hole. Like on the c8 op reflector. Wasn’t able to use them as is.
So that is also double the lumens, so 1300-ish? Nice!
In the meantime I wished for a 5000K version of the NM1 and the PM1. I plan to use the NM1 in the GT-micro but I’m also contemplating giving in a few lumens by using a dedomed XP-G2 S4 3D instead.
