Grinding is a bad idea I have wrecked a couple emitters doing it.
LCKLED has some 14mm U2s. I got some a couple weeks ago they were very nice. They are on aluminum boards not copper, unless you are mounting on a copper pill I don't see the advantage to using a copper board on a brass pill.
yeah would rather not have to shrink a board if possible though know its been done with good results. agrees 14mm to door step (good price and known good shipper) is best and scratches the copper to copper thing. as i thought below
oh ok i thought the copper stars were better efficient cause they had no dielectric between the leds copper heat path and the copper heat sink it was soldered too. if this makes no difference then duh i was over thinking it i guess ill stick with the aluminum then. below is what i was working off of didnt realize it needed a copper pill aswell. thanks
