Can´t wait to get the light
Insta-buy! 26650 version as well!
Cheers and thanks!
no problem ,i will get some 5000K
i will consider to produce some adapters if many guys need it
contactcr:I would recommend trying to get the 5000K SST40 Simon
Excellent!! :+1:
Hi Simon.
Could I order a Convoy S11 with an XHP70.2 ~5000K NW, no blinky modes and 0.1% > 1% > 10% > 100% levels and toggle memory by config ?
Also, are there any other different colors available to pick from for this host, like desert tan for ex. ? And if so, how much would all of this cost ?
Regards.
Simon, could you please tell us what SST-20 tints you’ve got in stock at the moment?
Hi Simon.
Regards.
sorry ,XHP70.2 can not be installed
another model with XHP70.2 run on single 26650 will be available soon.
currently ,there is only black
6500K and 5000K (Ra=70)
4000k (ra=95)
Same design as the S11, just 7x7 emitter compatible ?
i understand ,but it needs suitable reflector
the bottom hole of the S11 reflector is 7mm ,it’s small
Oh no, I was asking if the new design with the XHP70 will be basically the same design as the S11 / host :)
similar to BD06 ,but little bigger
Ok then, I suppose it's going to be an S11 for me with the XHP50.2 for the moment :)
Do you happen to have a beamshot of the S11 by the way ?
Regards
Ok then, I suppose it’s going to be an S11 for me with the CHP50.2 for the moment
Regards
Light spot is very wide, It’s daytime here, Not convenient to take a photo,
Perfect then, thanks a lot. I'll take one S11 with 5000k XHP50.2 if still available :) And about the driver, do you have a 0.1 > 1 > 10 > 100 % version ?
Hey Simon,
are you going to sell the sst20 LEDs separately?
Perfect then, thanks a lot. I’ll take one S11 with 5000k XHP50.2 if still available And about the driver, do you have a 0.1 > 1 > 10 > 100 % version ?
sorry ,mine is 0.1–3–30–100
Hey Simon,
ok ,i will add links later
I guess it's fine like so as well, it has the 0.1 and that's what I was the most interested in.
So how would I order one S11 ?
Thanks.
