I won’t buy a flashlight thrown from the 50th floor with tons of nicks and cracks. :smiling_imp:
I would much prefer an FW3A machined out of ice, to not be burn if it accidentally turn on in the pocket + active cooling for max lumens :+1:
The excerpt below, taken from THIS ARTICLE ; tells what they did.
“The pistols are fully-functional – and resultant of their National Match barrels, accurate; verified both on the rest and in off-hand shooting. Leaving nothing to chance in terms of functionality, our engineers used electron beam technology to meticulously add bimetal support only to the frame/slide rails, hammer, guide rod and extractor of the Big Bang set. – and the pistol’s components, down to the barrel bushing and trigger – are 100% Gibeon meteorite.”
Im not above saying something stupid but…. I suppose it is no more ridiculous than flashlights made of meteorites and hiking boots.
Actually I was serious(but as I mentioned earlier in the link above)as a custom clip that would work on the bill of a cap…. why wouldnt this design work if the other clip could be removed? I realize this design would not be preferred for a ‘dedicated’ pocket clip even though it could still be used as one(using the 1st bend) but more important to me, also on the bill of a cap. As I said earlier, I dont like or use pocket clips and would probably remove the current clip if it wasnt glued.
I would personally prefer to be able to use the clip on a cap, or remove it, so I hope it is not glued. If it is glued, I will use it with the clip as is, and be fine with it.
