【convoy】H4 and B35AM options are updated
Light spot is very wide, It’s daytime here, Not convenient to take a photo,
Perfect then, thanks a lot. I'll take one S11 with 5000k XHP50.2 if still available :) And about the driver, do you have a 0.1 > 1 > 10 > 100 % version ?
Hey Simon,
are you going to sell the sst20 LEDs separately?
sorry ,mine is 0.1–3–30–100
ok ,i will add links later
I guess it's fine like so as well, it has the 0.1 and that's what I was the most interested in.
So how would I order one S11 ?
Thanks.
Hi Simon,
1) Can you give some info about the “ramping” operation that will be used on the S11?
2) I would also like to ask around how many lumens is the SST20 6500K, assuming the 7135x8 version?
(The 7135x8 version of the S2+ with XM-L2 and XPL-Hi 6500K LEDs are usually indicated to be around 1000 lumens, so I wonder if the SST20 might be a bit less, but have a more “throwy/focused” beam pattern due to its smaller LED?)
sorry ,what 0.1?
1 click - turn on 1st mode 100%
2 taps - 2nd mode 30%
3 taps - strobe or biking or 0.1% moonlight or …etc
when flashlight is on 1st or 2nd mode
5taps - ramping,you can set the brightness of 1st or 2nd mode here .
when flashlight is on 3rd mode
5taps - you can choose one mode from strobe or biking or 0.1% moonlight or …etc
2) brightness the same as cree xml2 and xpl hi
0.1% moonlight mode.
Estimate release date for the ramp version?
oh ,i see :smiley: ,driver still needs half a month, :person_facepalming:
I add link of SST20 here
Could you mention the flux bin, colour bin and voltage bin of the SST-20 leds? (i.e. a picture of the package label will show that)
Good price btw when 5 pieces are bought! :slight_smile:
That's ok, I've just seen it on the first page and I though it was already available.
Simon could you add XHP50.2 K2 3C option for S11 and only led +MCPCB
That’s great, thanks!
Another question: Will the boost-driver of the S11 have mode-memory, and if so, can it be disabled?
ok i updated the description
what about 3A 3D? i will add link later
