13583 posts / 0 new
oweban
oweban's picture
Last seen: 1 hour 45 min ago
Interested dependant on cost of shipping to Australia!
raccoon city
raccoon city's picture
Last seen: 9 hours 9 min ago
I would bet that worldwide shipping is included in the price.  ;)
oweban
oweban's picture
I really need to not respond to threads first thing in the morning Sad
Coscar
Coscar's picture
Last seen: 14 hours 13 min ago
ToyKeeper wrote:
Coscar wrote:
Something like this….
<_<
>_>
Not sure if serious or humor.
http://budgetlightforum.com/comment/1462635#comment-1462635
Im not above saying something stupid but…. I suppose it is no more ridiculous than flashlights made of meteorites and hiking boots.
Actually I was serious(but as I mentioned earlier in the link above)as a custom clip that would work on the bill of a cap…. why wouldnt this design work if the other clip could be removed? I realize this design would not be preferred for a ‘dedicated’ pocket clip even though it could still be used as one(using the 1st bend) but more important to me, also on the bill of a cap. As I said earlier, I dont like or use pocket clips and would probably remove the current clip if it wasnt glued.
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
teacher
teacher's picture
Last seen: 9 months 3 weeks ago
G0OSE wrote:
Ah I see, thanks Teacher for clearing that up.
My pleasure GOOSE. Thumbs Up
If you still want to be on the list, you may want to edit your "remove me" post. Wink
teacher
teacher's picture
Actually I was serious, but only, as I mentioned above, as a custom clip that would work on the bill of a cap…. wouldnt this work(if the other clip could be removed)? I realize it wouldnt work for a pocket clip but as I said above, I dont like/use pocket clips and would probably remove the current clip if it wasnt glued.
Good point…. Facepalm . Thumbs Up . Wink
cabfrank
Last seen: 19 hours 12 min ago
I would personally prefer to be able to use the clip on a cap, or remove it, so I hope it is not glued. If it is glued, I will use it with the clip as is, and be fine with it.
joechina
Last seen: 1 month 1 week ago
ToyKeeper wrote:
Coscar wrote:
Something like this…. ! !
<_<
>_>
I assume you don’t wear caps with a duck bill?
gravelmonkey
Last seen: 31 min 35 sec ago
DavidEF wrote:
Doesn’t meteorite tend to be brittle? I’d hate to be the first guy to shoot one of those guns to find out if it holds together. Shocked
There are different categories of meteorite depending on their composition.
The one above is an iron meteorite, composition as follows:
91,8% Fe; 7,7% Ni; 0,5% Co; 0,04% P; 2,4 ppm Ir; 1,97 ppm Ga; 0,111 ppm Ge
So mostly iron with a bit of nickel. If I remember correctly, these are likely to represent the core of large planetary bodies – the space material which has undergone differentiation (light stuff floats to top, heavy sinks to bottom leading to compositional stratification). Not too disimilar to earth – iron-nickle core and ‘scummy’ crust floats ontop.
Wiki link to the meteorite this material came from:
https://en.m.wikipedia.org/wiki/Gibeon_
Coscar
Coscar's picture
ToyKeeper wrote:
<_<
>_>
Sure got quiet ~~~~ I thought I might get either a “that’s a stupid idea because …..” or “thats a neat idea” or some response in between …….. I don’t know what to think…… maybe I AM missing something.
A little John Prine
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 3 hours ago
Coscar wrote:
Sure got quiet
People were complaining about the off-topic noise, and there hasn’t been much on-topic news to share… so it got quiet.
tatasal
Last seen: 2 hours 2 min ago
ToyKeeper wrote:
Coscar wrote:
Sure got quiet
Oh well, just to rekindle some interest. how about a photo of the ‘softer’ side of the fw3a:
!1549261301861!
funkychateau
funkychateau's picture
Last seen: 7 months 2 weeks ago
Here’s some on-topic noise. I just read the review of the recent prototype, which notes that the battery tube is not quite long enough to accommodate button-top cells.
Isn’t this a glaring oversight for a product that has been in development for so long, with several prototype stages already past? How difficult can it be to add 50 thousandths of an inch, so that another entire family of common cells can also be used?
I will be pretty disappointed to find this thing in production and still unable to accommodate the collection of high-drain cells I have accumulated for my D4, D1S, and Q8. I don’t want to have to maintain another special set of batteries for this one application.
cabfrank
Hmmm,I could be wrong, but I think this has been designed for flat tops since the beginning.
ToyKeeper
ToyKeeper's picture
funkychateau wrote:
Here’s some on-topic noise. I just read the review of the recent prototype, which notes that the battery tube is not quite long enough to accommodate button-top cells. … How difficult can it be to add 50 thousandths of an inch…?
Proto2 worked fine with button-top unprotected cells. However, proto4 only fits flat-top unprotected cells. I think this is caused by the known issue with the driver being in the wrong spot, and it should be fixed by correcting the driver fit.
It’s supposed to fit like this… which is how both proto1 and proto2 were made:
… but proto4’s driver cavity wasn’t made quite big enough, so it ended up more like this:
I hope it’s clear from the diagram why this could cause issues with battery length. Restoring that part to how it was in earlier prototypes should fix it.
cabfrank
So it was always supppsed to support button tops. I didn’t know that.
JasonWW
JasonWW's picture
Last seen: 1 hour 50 min ago
Welcome to the world of lithium batteries where there are no standards when it comes to the physical size. Wink
Unprotected flat top cells are recommended because button top may or may not fit. This was known information for many many months. In post #1 it says the maximum battery length is 66mm. If you have several button top cells then there is a chance some will fit and some won’t.
Unprotected flat tops, on the other hand, will all fit which is why they are recommended.
At first I thought you were talking about Bluzies review where a flat top battery did not fit, but that review was 3 weeks ago and was talked about here already.
What is this new review you speak of?
toddcshoe
toddcshoe's picture
Last seen: 30 min 20 sec ago
I don’t normally even buy button top cells. It is much easier to make a cell longer than it is to make it shorter. It would be nice if it fit both for the sake of those who don’t want to go monkeying around with their flat tops or, invested heavily in button tops.
"Everywhere I go, there I am"
JasonWW
JasonWW's picture
The battery tube length is locked in. It’s a very narrow range of lengths due to the double tube design and both tubes have to have good contact for good functionality.
It’s quite possible Neal will offer the light with the option of a good flat top cell. I have zero concerns about the battery length.
teacher
teacher's picture
Which “review” are you referring to?? Please provide a link. That information is not correct. The length of the battery tube was not the issue.
_______
Nope, not a “glaring oversight” at all. See above & see TK’s detailed explanation quoted below outlining the suspected real problem.
http://budgetlightforum.com/comment/1463968#comment-1463968
_______
Hopefully you will not have to deal with disappointment. Hopefully your particular accumulation collection of high drain cells will work just fine.
But, even in a worse case scenario (which seems extremely unlikely); the FW3A just holds one cell. So, in the very, very, very unlikely event of “worse case scenario”; hopefully you will be able to deal with the disappointment, get one or two cell that fit, & be at least moderately happy with the cool new FW3A. Thumbs Up
funkychateau
Thanks for the illustration of where the real problem lies. I had not seen that diagram, and probably never would, due to the time required to read through 7400 posts. Just for the record, I’m not lazy – I did read every post in the D4 review before buying, and also every post (to date) in the D4S thread, though I haven’t bought that one yet.
The issue seems to be simply a matter of paying more attention to the size tolerance of the various parts, which hopefully the manufacturer will address before beginning production. But yes, it would still bother the heck out of me to see so much good work go into this project and then have the versatility crippled by poor manufacturing.
dtom
Last seen: 6 months 1 week ago
I would like to buy one.
mortuus
mortuus's picture
Last seen: 4 hours 30 min ago
arent all high drain batteries flat tops anyways stock `? i dont even own a flat top battery for my highdrain lights that takes just 1 battery.
...where Frugal meets with Flashlight!
Coscar
Coscar's picture
Coscar wrote:
ToyKeeper wrote:
<_<
>_>
Are you still not sure if I am serious or kidding? Since you didnt respond to my post explaining the cap clip, I was not sure if you just didnt understand what I was trying to do or maybe there was something wrong with the design that would keep it from working…….. maybe it is a good design but without explanation your reply suggests otherwise.
A little John Prine
JasonWW
JasonWW's picture
All 18650’s from the big Japanese makers (Sanyo/Panasonic, Sony, Samsung and LG) are all flat top. Aftermarket companies add button tops to them.
ToyKeeper
ToyKeeper's picture
Coscar wrote:
Are you still not sure …?
No, you clarified. Smile
It looks like it would work on a baseball cap, if it’s not too heavy, but wouldn’t work very well in most other places. If I had one I would probably take the clip off, or maybe break off the extra fold.
Henk4U2
Henk4U2's picture
Last seen: 28 min 30 sec ago
C’mon, lights have feelings too, you know?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
JasonWW
JasonWW's picture
TK, since no one from Maukka’s review has asked here yet, can you tell us why the two battery tubes in the FW3A can not be equally lengthened 0.5mm to 1mm so as to make it fit both flat top and button top batteries?
(Right now it only fits some button top, but not all. Max battery length is 66mm)
I figure there must be a reason and it was probably determined over a year ago, but people where asking and I don’t know the answer.
ToyKeeper
ToyKeeper's picture
It’s mostly just too late, and would risk making shorter batteries lose contact when bumped.
Also, I think Lumintop may have only a compiled version of the 3D model, without any way to modify it. They might need the original from Fritz instead of an exported / compiled version. I’m not sure about the details though.
Scallywag
Scallywag's picture
Last seen: 23 hours 9 min ago
I'm surprised this has even come up. High-drain cells are flat-top by default. Button-tops are weird and abnormal for high-drain, unprotected cells. (I actually had to be very careful buying batteries for my L6 for this reason!)
Aren't most super-compact lights advertised similarly, some kind of "unprotected/flat-top only, others may not fit"? My Zebralight SC62, Lumzoo GH10, and Emisar D4 all have battery fitment concerns. Two of those aren't even high-drain! I'm sure we will get reviews very quickly in which members measure very precisely and test with a variety of cells, between protected and not, button-top and not.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
