Interested
Interested in LH351D 4000K 90CRI if it has not the driver glued, may be screws like the Q8 or retaining ring like the GT or the Astrolux MF series the to hold driver in place.
Maybe interested.
My suggestions for LH351D:
5700K 80CRI or 6000K 90CRI (LH351D has this latter option as well, checked that from documentation)
5000K 90CRI
3500K 90CRI
Sofirn+Anduril. Interested
nterested. I would probably choose 5000K W6
Oh yea, no glue = INSTA BUY
This light has so much mod-potential, ruined by glue.
Interested in a NO GLUE 4000K 90CRI
Interested in NW or WW for one.
Interested in 4000K or warmer
About the no-glue thing, it’s worth pointing out that the SP36 would need host modifications to make it work without glue. It would need screws or a retaining ring or something. Because without glue, the driver falls out every time the body tube is unscrewed. And then if it’s in the wrong place while putting the light back together, it can cause a short and turn its own wires into smoke. I know this because it happened while I was testing an unglued sample.
So it’s not a simple matter of just skipping the glue during assembly.
I hope some sort of solution can be found though. It’s a really nice light, but the glue seriously limits the potential.
Understood. But as you pointed out - replacing the glue with a screw on the driver should be rather trivial.
^ the screws need to go somewhere. Like in the Q8, the driver cavity must be reduced in favor of two extensions of the shell that house the screw holes. That implies that the driver cavity must be machined instead of turned (it is not round anymore) which is a bit more expensive. Also the driver lay-out must be re-designed to clear the areas where the driver sits on the protrusions from components.
The thickening of the shell walls where the driver screws go do provide the opportunity to add the tripod hole btw, 90 degrees from switch and USB-port.
Interested in one with LH351D 5000K W6.
As djozz explained, it’s not trivial. Eliminating the glue is actually a pretty big request.
I am interested.
Interested. (very)
Prefered form factor plus with Anduril - checks;
Glued driver - negative.
Will see to mod this problem. Not many lights check all my requirements.
I am interested, got the original but that wont stop me.
Orange or red switch LEDs would be great!
Also what tint bin will it be? We want below the BBL tint. Most of the Samsung LH351D are above the BBL and too green for my taste.
Interested. Thanks!
Interested in a lower moonlight…
