hurray, 100 watt iron arrived, one touch soldering with the star in situe, installed Gcharts ramping UI 2nd attempt and it works. (NANJG layout on the red convoy C8 board).
running temperatures are spot on, and the ramp down works on turbo/max ramp, also the battery check is as close as.
draws 1.7 amps with the battery at 3.7v at the battery end on turbo/max ramp, thats that sorted.
thank you everybody, i actually got help on here, nice one.
edit: and just confirmed the LVP works too. (battery at 3.11v after a few minutes rest. light switched off).
I hear the Olight Warrior X is pretty good for tactical purposes. There are lots of others to choose from in that general category though. I’m probably not the best person to give tactical recommendations, since I don’t really know much about it.
Crescendo could be modified to start in turbo. You could just reverse the ramp table so it starts with 100% FET, and turn off memory. I think this would start in turbo then automatically ramp down? I’ve always used memory so I’m not certain how it behaves with no memory. Is there an additional simple modification to make it just turn on in turbo and stay there?
For that, I’d recommend Anduril with the START_AT_MEMORIZED_LEVEL option turned on, maybe also with the boot code modified a little to do turbo by default instead of memory. This way, the tail clicky switch would work as a tactical momentary button, while a side e-switch provides access to ramping and all the other general-purpose stuff.
Or Crescendo could be modified to start at the top instead of the bottom, but it’ll still be prone to doing odd things when bumped. Even with modifications, I don’t think I’d recommend it for tactical purposes.
ahh yes tactical… but strobes gunna be a dead give away, can you imagine it, out side the cartell, everyone’s in position, shh….shhhhh? whats that noise? i mirrion candle power strobe mode…WITH RAMPING!!..
Some firmware projects have recommended fuse values inside the source file. However, for all of mine, check the bin/flash-tiny*-fuses.sh scripts in the code repository to see the most up-to-date recommended fuse values for each MCU.
Okay, I just updated a bunch of source files to remove any outdated fuse info from the .c file and replace it with a pointer to the flashing scripts. Those scripts are much more actively maintained, and more likely to be correct.
In the bin/flash-*-fuses.sh scripts in my firmware repository, it has recommended fuse values for each type of controller chip and usually a link to a calculator which shows what those values mean.
In most cases though, the fuses don’t need to be flashed. Sending a .hex file by itself is typically fine, and less risky.
Almost there. But it’s not under ToyKeeper/ , it’s under bin/ .
BTW, to compile the code for an arbitrary driver, you’ll probably need to edit the source a little bit to choose relevant settings. And the crescendo.c file also points to those same flashing scripts for info about the fuse values.
ToyKeeper, I just wanted to say a big THANK YOU! for all of your hard work creating these awesome flashlight interfaces for all of us flashlight fanatics to use—your work is very much appreciated!
