thanks for your time.
the E3’s middle mode is realized by PWM, so you can find the strobe.
Rgs
Rgs
Yup, I noticed that! But it can only be seen under a camera, naked eye doesn’t see it (well, at least my eyes don’t see it)!!
Again, great work, I love this flashlight :+1:
thanks for appriciation.
we will do our best to make lights.
Hi. I actually created an account so I could comment in this thread. I use Eneloop batteries and prefer warm light, so I’m in the target market for flashlights like this one.
I’ve had a Jaxman M2 in 4300K for about a year and I love it. The two-mode control is wonderfully simple and the modes are nicely spaced. It does everything I need from a larger flashlight and effectively retired my old D-cell incandescent Maglite. I like the 2xAA size and I don’t think they get enough love.
I was very interested in this E3 but the PWM turned me off. I like the extreme battery life of a super low and I appreciate lights that preserve night vision by starting on the lowest setting. Super high can be useful but I rarely use it. The medium setting is right in the sweet spot for me, both for light level and battery life. Having PWM in that mode makes it much less attractive.
If Jaxman releases a version of this in warm color with high CRI and no PWM, I’ll buy a few of them.
hi friend, I had thought that the middle mode is the most seldom to use for most users….
so I set the PWM mode in the middle mode.
I am thinking about it and how to deal…
Rgs
Thanks for the consideration. My specific interest is in finding warm and/or high CRI lights that offer a great balance of light and run time on NiMH without PWM. Having it start in moonlight mode is an appreciated bonus. High/turbo is usually my least-used mode in this size of flashlight. I like having the option but I don’t always need that much light. When I use the high mode, I don’t usually need it for a long time. At times when I want a lot of light for a longer duration, it would usually be longer than possible with a single AA or AAA anyway. When I want more light, I’ll just reach for a more powerful flashlight like your M2, which can handle bigger outputs for longer.
BTW, I just purchased a second M2 because I like it so much. I also have your AA UV flashlight with filter. My experience with your products has been extremely positive. Seeing you here, taking time to engage with your customers and listen to what the gear community wants, is fantastic. It encourages me to recommend your products to others.
If you figure out how to implement without PWM, make sure you tell people about this feature on your E3 product page. For some people, no PWM is an important feature.
Sorry for updating this but, how many versions of Jaxman E3 there are?
Seems the first version is from 2016 and “this version” is from 2018. But any changes on the name, V1 or V2 or something like that. I little bit confusing to find.
The first/old versions of the E3 are not on sale (at least on Jaxman AliExpress store). You can find “copies”, but not the original is not sold anymore.
The new version, is: Page Not Found - Aliexpress.com
There are no changes in the name, but there are changes in the structure of the falshlight as you can see on the post#1 of this thread
Has anyone replaced the LED on the E3 with an XPL HI? I have been wondering about this, just replacing the the led but keeping the same driver. Would I gain any more output and runtime compared to the nichia? Another thing, does the XPL HI emitter fit in the stock reflector opening?
Hi lg.tech! Welcome to BLF :partying_face:
I just wanted to let you know that XP-L HI emitters will fit well on this flashlight’s reflector! Any 3535 footprint emitter will fit well (XP-G2, XP-G3, XP-L HI, XP-L HD, some Nichias, Luxeon V2, and others).
I modified my light and I don’t have the original driver anymore, so I can’t do a runtime test. But, I guess runtimes on this flashlight will probably depend more on the type/quality of batteries you will use and on the levels you will use than the LED you’ll have on it.
Enjoy your flashlight!
Thank you for the welcome and for your response!
Do you know what size PCB I can fit in it? I’m thinking of getting the noctigon 16mm.
I love this light, I got the nichia 4000k version, but for outside usage it’s fairly weak with this tint. I have an old Nitecore D11 which has a similar output but with a cool white emitter and it’s much more usable, so I thought about putting an XPL HI 5000k on the jaxman E3.
As for batteries I have Standard eneloops, Sony 2400mAh Ni-MH and Efest 14500. I normally just use it with the Sony batteries, runtimes aren’t great with any of them, my old Nitecore D11 has a better runtime.
You’re welcome
You can fit a 16mm diameter MCPCB. However, please note that if the Noctigon is thicker than the original PCB, it may leave a small gap between the bezel and the edge of the head where it screws in. You can add an extra o-ring there to maintain it more or less “sealed”.
About batteries, in case you want to use it with 14500, you can take a look at these Vapcell batteries: Test/review of Vapcell ICR14500 1000mAh (Gold) 2018
They have higher capacity than the Efests, and as this is not a high drain flashlight/driver, they can give you some more output and still last for a while.
However, note that Jaxman adivises to use more the Ni-MH batteries than the 14500 Li-Ion.
I guess the 5000K XP-L HI is a great choice, it is neutral white colour and will be good for indoor and outdoor. Also, it will not produce tint shifts under the Jaxman reflector.
The Noctigon MCPCB is 1.6mm thick. https://intl-outdoor.com/led/xp-l-hi/noctigon-xp16-cree-xp-l-high-intensity-v4-3c.html
Looks like I’m gonna have to wait a little while before I can try this. The shipping estimate for me is over 3 months due to the pandemic.
Hum, you can try other sources: 2.34€ 66% OFF|XPL HALLO V2 1A / U6 3A / U6 4C / U4 7A LED|cree xpl|cree xpl hixpl hi - AliExpress
It is not a Noctigon, but it is a DTP MCPCB (Direct Thermal Path). It is sold by Convoy Store, run by Simon Mao.
You can ask him if he is currently shipping to your place.
Or you can check other sources, such as Kaidomain.com or their AliExpress store (7.25€ 5% OFF|Cree XP L HALLO 10W 3A 1095 Lumen 6500K 5000K 4000K 3000K SMD 3535 LED Emitter auf KDLikter DTP Kupfer MCPCB Taschenlampe DIY|led emitter|neutral whiteemitter led - AliExpress)
In any case, it is better to check with sellers before ordering.
That’s funny, I just talked to Simon yesterday about ordering a S2+ but unfortunately I’ll have to wait.
Hi Jaxman, liking the look of your new X2. Any chance of making the host available on your AE store? I would love an E3 host as well!
Has anyone measured the lumen output on the E3?
One other thing, I have been thinking about how the E3 would perform with a smooth reflector, does anyone know where I could find a smooth reflector for the E3?
I have a Nitecore MT2C and on the lowest level (measured around 38 lumens by reviewer selfbuilt) it’s noticeably brighter than my E3 on the mid level looking at about 1 meter distance.
I’m thinking of getting a Jaxman E3 to mod. What size driver will fit? And what did you swap it to?
I’d like to put something with better UI in there as well as swap the LED.
