Lumintop GT micro
Ordered already… cool white and 1000mAh battery (because I don’t have 14500s around)
Ordered , thanks Martin .
Will these do for the GT Micro?
Enercig (Tensai) TN14500HP- 650mAh 3,6V - 3,7
Is anyone able to tell me what size MCPCB and driver this light uses?
I’m keen to try a white flat in it. Having not used a white flat yet, would it be ok with the stock driver in this light or would I need to swap it out with a lower current regulated driver?
Ideally you want a 12x7135 driver with e-switch control and those are not common. The stock direct driver could work fairly well because 14500 batteries show more voltage sag than 18650 batteries.
I did not measure it but it seemed a little smaller then a normal 16mm mcpcb. I think you could sand down a 16mm mcpcb to fit though.
A white flat was donated to me recently. Once I know I am done with the prototype I plan to install one in the GT micro if I can make the mcpcb fit.
14mm mcpcb
17mm driver
(on my prototype)
Wow, will anyone sell me the driver?
I estimate exactly 100 kcd, a bit higher if the reflector is really good.
Somehow, I hadn’t read about this light until now. It reminds me a lot of the BLF X5. It was cute, and the copper version is pretty, but ever since getting a D1 I haven’t had much use for the X5 or X6.
Anyway, a quick spec comparison of similar lights…
GT Micro: (manufacturer’s specs)
  • 36 mm wide
  • 105 mm long
  • 600 mAh Windyfire 14500 cell recommended
  • ~400m throw
BLF X5:
  • 31 mm wide
  • 108.5 mm long
  • ~333m throw
Emisar D1:
  • 34.8 mm wide
  • 74.8 mm long
  • 1150 mAh 18350 cell recommended
  • ~400m throw
I usually leave the D1 in my purse, soft-locked. It’s small enough I can forget about it until I need it… and it’s not often I need something with more throw. I have it flashed with Anduril, and configured to run in stepped mode with a high enough floor that I often don’t even need to unlock it to take a peek at something in the distance.
Rationally the D1 is the better light, an improved GTmicro with a superior battery, but I really like the shape of the GTmicro, and maybe it helps a bit that it is a bit slimmer and more lightweight.
Well… let’s hope that the GT Micro reflector is better than D1 one
the Emisa D1 is 43000cd & the gt micro is 52000cd ,so in theory the gt micro will throw further?
if that’s true ,then for how long (time) will the gt throw further ? the d1 will run on a 30q @3000mah & the gt run on a high drain 600 mah 14500.
An 18650 will slaughter a 14500, no question. It was never meant to compete with an 18650 based light, the GTmini is for that. This is a smaller version for fun as much as anything.
Although having used it some, I can say it is actually a nice light overall all things considered.
It’s a nice form factor. Small, comfortable, generally sleek. It’s physically pretty similar to a popular Maglite model, and that model was popular for a reason.
Looking back at the X5 though, the #1 request was that people wanted it to use an 18650 cell, to increase power and runtime. The head is wide enough that the wider cell would probably be a nice fit.
On a related note, one of the top feedback items on the D1S (and the GT-Mini) was that it should have maybe used a 21700 cell, for similar reasons.
Yes, I like the idea of 21700 based lights as well, sadly they did not heed my suggestion that the GT mini should be made into a 21700 light.
I think it would of been a great combo.
I really like the Sofrin C8F? that is 21700 based.
+1 on the GT Mini 21700 (and maybe an XHP35 HI as well)
Also +1 on the Sofirn C8F which seems so far to be my all around go to - it has pretty much of everything - enough throw, plenty bright, enough spill, good ramping UI, mechanical forward clicky so no parasite drain.. If only it would've been a single emitter (with the efficacy of the 3 it currently has tho) like a C8/GT Mini and with a more refined beam pattern..
The Swiss Army Knife conundrum, having everything everybody wants all the time… due to the very nature of a flashlight, someone is guaranteed to be disappointed no matter how epic a light is made. Hence, the reason some of us have so many. :wink:
I don’t know if anybody has actually answered this yet, but the 2.5 amp that was mentioned in the early version of the GT manual was just a misprint. It was copied and pasted from the original GT manual. It can be disregarded.
Apparently Lumintop is still inadvertently using that 2.5 amp rating for the Micro. :person_facepalming:
I recieved a Micro from Neal today. It’s pretty cute and pocket friendly. I’ll do a quick review of it.
The quality is just as good as the Mini, just smaller. I have the Cool White version.
Unfortunately I only had a protected Evva 800mah 14500 non-high drain battery in my stash.
I did some tail cap amp draws using the UT210E clamp meter.
Top of ramp - 1.65A
Turbo at 3 secs - 2.75
Turbo amperage dropped fast due to this battery. I thought about buying a Windyfire and wait till it gets in to report my findings, but I decided to rip the protection circuitry off instead to see what happens. There was only a small increase in output.
Unprotected Evva 800mah
Top of ramp - 1.80A
Turbo at 3 secs - 2.90
Turbo at 30 secs - 2.40
I used my Maukka calibrated TA Lumen Tube to measure the output.
Top of ramp - 470 lm
Turbo at 3 secs - 770 lm
Turbo at 30 secs - 690 lm
To measure throw I use my LX1330B lux meter at 10 meters.
At 10 seconds I got 53Kcd or 460 meters.
At 30 seconds the output dropped to 46Kcd or 429 meters.
Not bad for a tiny light running on a not so great battery. I want to order a high drain cell to see what it can really do. :smiling_imp:
Parasitic drain was lower than the Mini at 140 microamps with the switch light on and 0.3 microamps with the switch light off. The Mini was 180/20. Did anyone else get a super low drain for the switch light being off? That’s crazy low drain.
A few pics with the Mini:
The rubber button is just a tiny bit smaller on the Micro.
It’s surprising just how small it is compared to the Mini. It makes my hand look giant. Lol
EDIT:
I recieved my high drain Windyfire 650mah button top battery. Here are the updated numbers.
Tail cap amp draws using the UT210E clamp meter.
Top of ramp - 2.2A
Turbo at 3 secs - 4.6A
Turbo at 30 secs - 4.1A
Top of ramp - 650 lm
Turbo at 1 secs - 1100 lm
Turbo at 30 secs - 970 lm
At 10 seconds I got 63Kcd or 502 meters.
At 30 seconds the output dropped to 60Kcd or 490 meters.
