^ not following common sense is the short answer, these questions have come up before and in the long answer I certainly brought up both the language and cultural barrier. Still even for a chinese company with their chinese way of doing things I think that following a “western” approach to developing new products would be beneficial overall.
Messing around with an idea for a dual-purpose clip thats only possible due to the FW3A’s geometry. Default is a deep carry, with a cap clip on the tailside. The clip goes through itself, having to pull it out to get a cap-bill through. The sketch is exaggerated to make the design obvious. The first bend coming off of the body wouldn’t create a gap between it and the return bend
There is one part I am not familiar with however. It says in the original post that “An unusual feature is the electronic tail switch. This allows the light to do much fancier things than a clicky switch, yet retains the ergonomic benefits of a clicky tail switch.”
What type of extra things does the electronic tail switch allow us to do that a clicky switch wouldn’t?
A mechanical tail switch is on or off and uses “off time” or “on time” to determine the action you are making. An e-switch can have hold functions and utilize single/double/triple/etc.-click operations without the light turning off at all.
If you’ve used any of the Emisar or Fireflies lights, its allows for an updated version of that UI vs something like Bistro or Biscotti where its just taps to do a quick power cycle that also changes modes.
That sounds very useful. I’m mostly used to dual switch lights, so I didn’t realize single mechanical switch lights would have an issue with turning off when you switch modes.
Yeah, a mechanical switch physically disconnects power. It literally can’t keep putting out light while the switch is off, because it’s effectively unplugged. The user interacts with it by connecting and disconnecting power, which makes it a little difficult to do anything fancy.
An e-switch works more like clicking a mouse on a computer. It can be up or down, but in both cases the computer keeps running while you press the button.
Stuff like “hold the button to ramp” doesn’t work on a mechanical power-disconnect switch.
