Group Buy: Wuben TO50R HC ("The Flashlight") - 90+CRI, 2500+lm, EDC - CLOSED!
Does it have battery level indication? Do you know how much it weights?
Im interested simply because it is carclo optic compatible so very easy to swap. Another reason is the very efficient driver tested by Maukka. Too bad no usb-c and same extremely difficult to find buttons in the dark as the 7 18650 versions I own. Price seems very high though. Its Acebeam and Olight level without the track record.
What kind of driver is it using?
A boost or a buck?
Interested depending on the group buy price.
Interested depending on price
Same as above
Also interested depending on price.
Interested depending on price, thanks.
Interested
What’s the optics? Carclo 1062x?
Need a lot more info. Quad LH351D?...how long does turbo last in something that small? Reflector? Range? USB mode specifications? PWM? Mechanical or e-switch? Parasitic drain if the latter?
Carclo optics, not a reflector. Its a quad.
E-switch, a bit obvious from the UI diagram I would think?
Interested as well, price-dependent.
Interested (but seems expensive)
Interested depending on price…
No answer about what kind of driver it is using?
Interested, depending on price.
Interested
interested
Please sign me up.
