[alive: M4D deal] jetbeam RRT1 950 Lumen
Lots of conflicting information about this light everywhere, but I think it looks BA :slight_smile:
Sent the interest form!
Too early. I would consider after reading some trustworthy review.
Mike
I'll probably receive it in 2-3 weeks. What questions do you want me to respond to? I can compare the control ring function to that of the Acebeam K40M.
Interested, subscribed. Thanks.
Build quality, runtime with graphs to see how driver is doing etc.
I have k40m too, control ring is perfect in that light.
Mike
which info is conflicting?
that 6 is a typo
this light is NOT 18*6*50 compatible, it IS 18*3*50 compatible
That be a real nice addition to this light if they offered a longer 18650 tube like Sunwayman did with the 14500 tube. :wink:
Hint hint Jet-Beam.
I’ll subscribe M4dM4x, I might be in for another if the price is right.
Thanks, that was the main thing. Else it says USB cable included but the light has no port, but as I have read into it a bit in that loooong RRT01 thread it seems that a 16340 is included with USB charging built in.
Interested
Interested
Thanks!
agree
like the RRT-2
yes
and fwiw, only Unprotected 18350 fit
and fwiw, the 750mAh Keepower 18350 does NOT work (unless you add a solder blob or magnet to the flat top)
and fwiw, the 1200mAh Keepower 18350 DOES work!
https://new.qq.com/omn/20190215/20190215A0XU3I.html
Chinese review with beamshots and runtimes
It’s nice of Jetbeam to humanize the tail. :slight_smile:
thank you, that review also shows the new model is 26 grams heavier (53% heavier, empty) than the old model
Thats funny, as i was thinking about what would be the best UI, i thought why not use the good old potentiometer :wink:
This digital variant will be the same idea, very neat!
Subscribed
Interested depending on price.
Interested. Thanks!
i ordered one form HKE last week! Oh should have waited :frowning:
But if price is good and the light is nice, might order one more.
Interested. I love rotating ring variable brightness control. I just wish it had USB charging. Not a single magnetic ring brightness control with usb charge in existence.
true, but, the 16340 battery included in the new RRT-01 has USB charging built into the battery
the Olight Universal charger works well, for charging the 18350 battery I use in my RRT-01
it turns any light and any battery (both LiIon and Eneloop), into a USB light, or battery :wink:
that means I can charge both my RRT-01 and my Maratac, with the Olight charger…
choices are good:
if the charger is in the light, it means I cant use the light, so I prefer an option that lets me keep using the light by just changing cells and charging outside the light
