Thanks, that was the main thing. Else it says USB cable included but the light has no port, but as I have read into it a bit in that loooong RRT01 thread it seems that a 16340 is included with USB charging built in.
Interested
Interested
Thanks!
That be a real nice addition to this light if they offered a longer 18650 tube
agree
like the RRT-2
yes
and fwiw, only Unprotected 18350 fit
and fwiw, the 750mAh Keepower 18350 does NOT work (unless you add a solder blob or magnet to the flat top)
and fwiw, the 1200mAh Keepower 18350 DOES work!
It’s nice of Jetbeam to humanize the tail.
Chinese review …
thank you, that review also shows the new model is 26 grams heavier (53% heavier, empty) than the old model
I agree, the pic shows the new one is fatter. I only have the original [image] My Original RRT-01 Weight: 49 grams w pocket clip, empty the weight with battery, depends what kind of battery I use, my 18350 is 25 grams, so my carry weight for the old model is 74 grams including battery. this review 404 您访问的页面找不到了_腾讯网 says the new RRT-01 weights 75 grams empty [image] that tells me that the new model weighs 26 grams more than the old model. I like to use my tools to hunt white walls, and …
Thats funny, as i was thinking about what would be the best UI, i thought why not use the good old potentiometer
This digital variant will be the same idea, very neat!
Subscribed
Interested depending on price.
Interested. Thanks!
i ordered one form HKE last week! Oh should have waited
But if price is good and the light is nice, might order one more.
Interested. I love rotating ring variable brightness control. I just wish it had USB charging. Not a single magnetic ring brightness control with usb charge in existence.
true, but, the 16340 battery included in the new RRT-01 has USB charging built into the battery
the Olight Universal charger works well, for charging the 18350 battery I use in my RRT-01
it turns any light and any battery (both LiIon and Eneloop), into a USB light, or battery
that means I can charge both my RRT-01 and my Maratac, with the Olight charger…
choices are good:
if the charger is in the light, it means I cant use the light, so I prefer an option that lets me keep using the light by just changing cells and charging outside the light
Interested
Hy cant you use it if usb was built in to the light? I feel with usb built in will make this a perfect light for muggles
SKV89:I just wish it had USB charging. Not a single magnetic ring brightness control with usb charge in existence.
that means I can charge both my RRT-01 and my Maratac, with the Olight charger….
choices are good:
you might be right about the muggles, if the light has the charger built in, they cant Lose the charger
what I meant was
while the light is plugged into USB, I cannot put it in my pocket and take it with me
make sense?
I prefer not to tie up the light, to make it do the job of a charger, but that probably is not how a muggle thinks
in any case, the RRT-01 does not have USB in the light, but for a muggle, it does have USB in the battery…
muggle wins,
I win,
Jetbeam wins (no extra USB waterproofing to add to the light itself)
I have Sunwayman V11R and Jetbeam RRT01 purchased in 2013.
JETBEAM RRT01 made in 2019 can’t be missed.
If the price allows
This flashlight should not be for muggles
so this doesn’t have a tail switch like the V11R? You have to mess with the ring every time you want to turn it on?
what I meant was
If you dont ise the usb charge feature, it is basically a regular light. Just replace batteries when you need to. Simple as that. Dont see how the usb cable can hold anybody back.
