Thorfire VG10S....opinion
43 posts / 0 new
Spartan
Knobby wrote:
Airsoft Rifle Light ?
a) Would this Thorfire VG10S make a good mounted light.
b) How easy would it be to Mod to single mode only.
c) Would a Convoy C8 (or other) pressure switch fit.
Just kicking around a few economical idea’s………. Thanks
I think it would make a great airsoft light. The body is well made and the mid output is pretty good. I doubt it will get hot at mid output. The hot spot that annoys me would be perfect for you.
Moses came from the mountaintop carrying a tablet. The Words were....WITH GREAT LUMENS COMES GREAT REPONSIBILITY.
Spartan
robo819 wrote:
Probably end up ruining the reflector because the coating inside is very delicate and will chip , scratch and flake very easily. I have enlarged the hole in the bottom of the reflectors a few times , but it must be done slowly and carefully even then.
I wasn’t going to machine it, I was going to sand it.
I kept some of my small industrial machines, including a 36” edge sander. It should sand off without damaging the reflector. Maybe. Hopefully.
But I don’t know what I will get. My guess is a wider hot spot, but I’ve been wrong before. Often. Annoyingly often.
Has anyone tried it?
DavidEF
DavidEF's picture
Last seen: 13 hours 8 min ago
If you’re going to sand down the reflector (on the bottom, where the LED opening is) to de-focus it a little and get a wider beam, that can work. Just try a tiny bit at a time. It doesn’t take much to get out of focus. In fact, you might just pull the centering ring out and get enough by sanding it down instead. You probably need to back-fill at the top with a thick o-ring between the reflector and lens.
- The YKK Philosophy
Spartan
I’m expecting that a few mm can make a huge difference. Just don’t want to land up with an ugly black ring.
My first hurtle is that I don’t mind fixing things, but don’t like to break things. I tried to unscrew it by hand but got nowhere fast. I know I saw a thread where someone had taken apart the VG10. A bit of vodka fortifier……and I’m going to try it the next few days.
DavidEF
DavidEF's picture
A few mm could make it a mule. I’d start with 1/2 mm, then go 1/4 mm at a time until it looked right. Unless mule is what you’re going for. In which case, you could just take the reflector out and not use it at all.
Serlite
Last seen: 21 min 39 sec ago
I’ve found that when dealing with a stubborn bezel, sticking some hockey tape along the webbing of your hand between your thumb and index finger can really help you get a good grip on it, and also protect yourself from getting cut by a crenelated edge.
Spartan
Way less then I thought.
I thought about a mule, but unless it has a heck of a lot of lumens, too much dispersion. I’d settle for orange peel reflector.
robo819
robo819's picture
Last seen: 4 hours 31 min ago
Use some CLEAR Spray Laquer inside the reflector and make it much like an Orange peel. Just a very light coat from about 14 to 16 inches away and if it is not enough then another light second , or third coat , checking the beam between each coat until you get the desired beam you want , (much like using defusing film). Just don’t get it too heavy or it will not reflect the light out well.
Just be sure this is the route you want because once done it can not be undone.
Shown in one of Justin’s (Old Lumens) videos HERE
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
DavidEF
DavidEF's picture
Thanks robo! I had forgotten about that! Else I would have recommended it. Big Smile
Serlite
Just in case you wanted an idea of how DC-Fix would affect the beam pattern, I took a quick comparison shot.
About 2 metres away from the surface, on the medium brightness preset.
Not a great picture, but it gives you an idea of the change in how intensity is distributed and also the smoothing out of the tint around the corona.
nydude
Last seen: 2 hours 45 min ago
Hi,
There are a lot of people here with more light experience than me, and I don’t mod, but I have given away two thorfire lights and much prefer utorch or convoy for price/comfort/quality. Just my .02
good luck
sochi111
sochi111's picture
Amazing flashlight for the money. Those of you who use it for Airsoft. did you replace/mod the momentary switch or what modes do you use?
