fwiw, my HDS Rotary w 650mAh 16340 battery weighs 104 grams, and has no screwed on, nor deep carry, pocket clip option. And the HDS costs over 3x the price of the RRT-01
The HDS Rotary is the same 1” diameter but 1/2” longer, than the new RRT-01 which weighs 100 grams with a 1200 mAh 18350. The HDS is NOT 18350 compatible.
That means the new RRT-01 is shorter, has double the battery capacity, weighs slightly less, costs less than 1/3 the price, and the RRT-01 gets both WAY brighter, at least double the lumens, with the same emitter, and WAY dimmer, like 10 times dimmer or more!, than an HDS.
The HDS Rotary 250 has 24 hops in brightness, it is not smooth ramping like the RRT-01. I like the RRT-01 ramping UI better. The HDS Rotary requires using a tail button, plus turning a dial on the tail. The RRT-01 is MUCH simpler, no tail button, and imo the magnetic rotary dial on the RRT-01 is in a Much easier to use location, and is MUCH more responsive, than the HDS dial.
Half of the HDS Rotary 250 dial reaches no more than 2 lumens and above 110 lumens the HDS only has 2 modes, maxing out at 250 lumens.
otoh, the HDS Rotary can be purchased with a High CRI LED, which drops the max lumens to 200, and the HDS will turn itself off automatically, if the LiIon drops below 3v. On lowest modes, HDS uses PWM. RRT-01 uses Constant Current, which has its own version of flicker, ripple, or whatever you want to call it. Does it matter, nah. I own both. Do I like using PWM, no, but I dont like constant current ripple any better… it is what it is…
The HDS Rotary has a BUNCH of multi click interface and programming options, that Require training to access, and Requires referencing the manual to figure out. The HDS has a much more Vocal fan club. The silent majority of RRT-01 owners, stop buying lights after they get the magnetic rotary. HDS owners otoh, keep buying more and more of them, hoping for more throw, more brightness, more bling, and more “investment” value. The cost of an HDS Bezel and reflector, is almost the same as the cost as a complete RRT-01.
I have both HDS Rotary (which came out in 2011) and RRT-01 (which came out iirc in 2012). I EDC the RRT-01, because for me, it is “better”.
The RRT-01 can be handed to a muggle without a manual. I dub it the PoorMan’s Rotary… LOL!
l-r Folomov C1 10440 w 3000k E21a, Original RRT-01 modded w N219b 4500k 9080, HDS Rotary modded w N219b 3500k 9080
I have a digital scale, so I weighed the light. It weighs 75.43g total, the head alone weighs 56.40g from all the brass that’s in the pill.
The tube is thin and is very light feeling at 19.03g with the clip on. With a Aspire 18350 and all the marbles she weighs in at 100.34g.
Yelp, she’s a big girl. It really doesn’t feel that bad to be honest. In comparison my bored out for a 18350 Sunwayman V11R weighs 70.53g with a Aspire battery in it, 45.62g without.
The head on my original RRT-01 is 30 grams
the body with clip is 19 grams
seems the new model has an extra 26 grams worth of Brass in the head
lets say they did it on purpose, because they thought brass was a good conductor for the extra heat, from the 50% higher lumen output of the new XP-L LED
I question the assumption that brass is a better conductor than aluminium, but, I know people think brass is a good conductor (I dont)
brass actually conducts heat half as well as aluminium
and brass is 50% heavier than aluminium
but, lets not argue about alternative facts… LOL!
I think we can all just agree to agree, that the new RRT-01 extra weight is in the head, and the pill IS Brass
I agree
I just ran a little none scientific test. I held my RRT and the V11R in my hand on full power. Both lights (current modded) put out close to the same lumens with the same LH351D. The V11R has a slight output advantage but not alot. The V11R will get to a uncomfortable hot in about 55 seconds with the tube also becoming very warm but not hot. The new RRT I ran for two minutes and the head is warm but not uncomfortable and the tube I can’t feel has changed in temp, but maybe slightly. So all that extra weight in brass is doing something.
Awesome!
Thermal Mass or Thermal Insulation, for the Win!
the brass insulates the user, and holds the heat in much better! LOL
or to spin it another way
The brass absorbs the heat (it actually doesnt), so the LED stays cooler (it doesnt)
what would keep the LED cooler would be if the pill was Aluminium or Copper
and with those materials, the user would feel the heat in their hand more
another example of a poor conductor, Titanium
a Titanium TCR-1, wont get as hot as the Original RRT-01
not because titanium runs cooler… its just a better Insulator… better than Brass
If Jeatbeam is listening, give us back the smooth ball track and more thermally conductive, and lighter weight RRT-01 head
or… just ignore me
and make another one of those Titanium TCR-1 or Eye10 TiC models, with the Original head, not the new Brass Bullfrog Head! LOL!
(I tease you because I Love you)
Thanks to everyone for the detailed stats and info. Finally got the bezel open on mine. Deciding between a Samsung emitter and a 3K 90CRI XM-L2. My eyes are still accustomed to and prefer incandescent flashlight bulbs. Staying away from the 2019 version. Don’t really need or use 900 lumens. Most of my day to day usage is well under 50 lumens. And I remember when 60 lumens was considered tactical light territory
That Ti version is cool looking.
The 2x12mm blue fasttech trit vials came yesterday. There to long to fit the RRT01 slots, the width is fine. I had to do a little proxxon rotary tool surgery to make them fit.
I ground the ends of each slot about .5mm or so to gain enough clearance.
Cleaned the holes and added some kafuter UV glue, installed the trits, then hit it with UV light.
It might be dark but I can still see you.
If someone is looking to add trit vials to your new RRT01 the 2x12mm will not fit without modification as above. If you can find 2x10mm, they should fit without any grinding.
No worries. Kind of an annoying experience with BatteryJunction though. I ordered the light, 2 x 18650 batteries (for a different light) and 2 cheap battery cases. I knew the light and battery were supposed to be delayed until March 8th but they later sent me an update saying the case was delayed some 2 months and everything was on hold til then. Then they said that the cases actually would come in the same time so I could wait if I wanted. So hopefully I am getting my light in 2 weeks.
I hope it works out for you,they have been very good with me and handled problems quickly. I am even more anxious now,seeing Moderator007’s trit install,nice work.
A standby current drain is inevitable on the RRT-01, due to the lack of a physical on/off switch. There is no standby mode on the V11R.
For the RRT-01, the standby current fluctuated between ~50-65uA on CR123A (~55uA average). It was a little lower on 1xRCR, at ~30uA. For a typical 1400mAh CR123A and 750mAh RCR, this would translate into ~2.9 years before a fresh cell would be fully discharged, in both cases. This is not a concern, but you can always twist the head slightly to physically lock-out the light.[/QUOTE]
Thanks Jon, I read Selfbuilt review too. But do remember that 2,9 years was calculated down to 0V. Expect 1ish year to normal 2,5V as below 2,5V is considered sleeping zone for most Li-Ion batteries. Including the battery self discharge itself.
There’s a lockout function fortunately
Trits!!!
Major respect on your mods and photos… thanks for sharing
despite not being perfect, and what light is?
these new rotaries are fun lights, with a nice heavy chunk of brass in the head
and they have Trit Slots! and fwiw M4D M4X has a secret discount code… dont ask me, its secret… ask him
and
I think somebody should offer a few of the new RRT-01 customized to High CRI…, with Trits Installed!
anyone here interested in having Clemence build up half a dozen RRT-01 w E21a, and Trits!!!
or maybe Bob_McBob will surprise us?
confession
Ive been using an Eye10 with the stock LED and those supposedly Horrible Detents I ranted about recently… well… when Im not staring at the lumens on my light meter, and not white wall hunting the beam, those little detents are kind of fun. I can see how a muggle would like them.
penance
Im back to carrying my RRT-01 w SW45, the smooth dial is just so… smooth
and the pink tint is heavenly…
as you can see, Im consistently inconsistent, and often disagree with my younger self.
One way or the other… one of me is always right, some of the time. lol
There’s no better than Clemence to mod these and he has access to the biggest selection of E21A 9080 emitters which IMO is the best looking hi cri emitters available.
Jon, convince me not to buy this and suggest another interesting 18350 light under $100. I can mod it if necessary. If you do not succeed then i will have no choice…
LOL
if you want a magnetic rotary w 18350, this IS the way to go, if you appreciate a beam with a hotspot for general EDC
and at the price M4DM4X is proposing… I think its a great deal… Bird in Hand, go for it, then beat the bush and someday you may do better, if you can find an original, that weighs less, or a Titanium version, that has more Bling
did I mention the new one has Trit Slots? How can you say no? LOL
if you can settle for electronic ramping, a D4 might be OK, if youre ok with that beam style, and the potential to roast nuts
or if you can settle for a 4 mode triple with onboard charging, still w 18350 capability, there is the Mecarmy PT-16, but it does not have a ramping UI, nor a sublumen mode
Today, knowing what I know, the RRT-01 is a BUY!
its not perfect, but, it is here now
