Emergency Weather Radios
56 posts / 0 new
bikenber73
bikenber73's picture
Last seen: 1 hour 24 min ago
I pulled out my old Eton FR 300 and 400 after a few years of storage and found them covered in some sort of sticky film. It turns out that the plastic is breaking down. Its a common problem and Eton has a solution. Clean it with a decreasing product. Here
In doing this I broke a knob off Facepalm So now I am looking for a new radio!
Anyone have one they recommend in the $25 – $30 range. My only real requirement is that it has WB and will pull in an AM/FM station. My Etons didn’t exactly have the best reception.
Thanks
tundraotto
Last seen: 7 months 2 weeks ago
Been there done that with Eton….aka ‘Grundig’ aka ‘Tecsun’. I got a PR-D4W Sangean and have never looked back, fantastic reception. Best WB capable portable I have ever used and heard.
bikenber73
I found at least one that runs off an 18650 but the old wire and special plug treatment was done to the battery so I cant simply pull one out and pop another in. I would have to attach the positive and negative wires to the 18650 if I wanted to change it.
I am digging this one quite a bit. Over my budget but I am thinking it might be worth it. It can run off any 18350! Any 18350 so that’s good to know.
DBSAR
DBSAR's picture
Last seen: 1 hour 11 min ago
I wish there was one out there with everything built in, including a Micro SD or MP3 player for playing music from when there is no radio signals in the far back country. (with AM/FM Weather/SW, and rechargeable LiIon or external USB power.
bikenber73
Yea me to. I watched a review of this one and the only battery it operate off of is an 18350. I wonder why they choose the 18350, from the video it looks like there is plenty of room for an 18650 maybe 2.
I would have one in the mail it it ran off an 18650. I have a ton of those.
Still looking!
2 DOGS
Last seen: 8 months 2 hours ago
I bought a SAST N520 a while back.
It has AM/FM/SW / TF a LED light and it uses a 18650 battery and a USB charger.
For 12.68 it might be worth a try.
Mine works OK but not great, SW is pretty weak but I might just need a better antenna.
https://www.tmart.com/SAST-N520-FM-Radio-Mini-TF-USB-MP3-Speaker-with-LED-Flashlight-Red_p363126.html Davie
(The elder has the right to chase after fashion!) Facepalm
Pete7874
Pete7874's picture
Last seen: 4 min 2 sec ago
Nice find! Cool device. I love that it can use removable Li-Ion cells. I too wish it used 18650 instead.
Pete7874
Pete7874's picture
Is the SW frequency the same or different from NOAA WX frequency?
2 DOGS
I’m not enough of a radio guy to tell you.
It goes from 700 to 1900 meters.
I don’t know how that converts to megahertz.
Sorry. Sad
Pete7874
Pete7874's picture
Sorry. Sad
The standard NOAA channels are:
WX1 162.550 MHz 39B 7
WX2 162.400 MHz 36B 1
WX3 162.475 MHz 97B 4
WX4 162.425 MHz 96B 2
WX5 162.450 MHz 37B 3
WX6 162.500 MHz 38B 5
WX7 162.525 MHz 98B 6
2 DOGS
The Google says that 162.400 + is VHF and doesn’t come in standard SW radios. Sad
tundraotto
No – most SW receivers (or any other receivers unless specifically mentioned) do not cover NOAA WX/Weatherband.
bikenber73
bikenber73
I ordered this one found one that’s refurbished and guaranteed for 90 days . I’ll just use it a bit to be sure it’s working. Maybe I’ll buy an new JB 18350 light to go along with it next month.
Need a few more 18350’s now!
Pete7874
Pete7874's picture
bikenber73 wrote:
I ordered this one found one that’s refurbished and guaranteed for 90 days . I’ll just use it a bit to be sure it’s working. Maybe I’ll but an new JB 18350 light to go along withe it next month.
Let us know what you think of it once you get it.
Boaz
Boaz's picture
Last seen: 2 days 16 hours ago
 Sadly the new stuff is just junk . Grundig as well as other sold out and are now made poorly in china, Their name was bought  or they just don't care any more . I have good old radios and wish for some added new technology added but who wants bad receive/poor sound quality and cheaply made junk that breaks after a few years . radio has followed in the Chinese footsteps of ( we can make it cheaper / work worse / break faster and you can sell your reputation, your good name and customer base down the river) .  Short wave reception on these radios is a joke . They add endless needless worthless items to these radios to try to add value .( Where's the seat belt cutter or the compass ) ?
 I'd like to modify a few older radios to run off of 18650's and add a charging circuit to the ones that take D size batteries .Plenty  of room to work with. Generally I opt for radios that run on AA's  since I have so many eneloop/rechargeables.
 the internet  killed radio
tundraotto
Let us know how you like it – I’d be willing to bet you did well for the price.
Couchmaster
Last seen: 1 hour 32 min ago
I just bought the Kaito ka500L. It’s unbelievably cheaply built and I wouldn’t get another. It looks great on paper. The L suffix is for “Long Lasting”. Basically it’s a ka500 with a 18650 battery for “longer lasting” LOL. They beefed up the solar panel as well which means instead of some marginal POS that doesn’t tread water, it will very slowly charge. I left mine in the window and it charged up from 3.702 volts to 3.76 volts in a couple of cloudy days. Which, by way of reference, is less than if you turn the crank handle 20 times. Regardless, at $50 it’s a very cheaply build product, the knob to select AM/FM/SW is poorly designed in that the choices are so close together that the cheap little POS plastic knob they use makes choosing channels a chore. The first one I got didn’t have the AM working, Kaito customer service was supurb and they quickly traded that one for one that was working. The builtin light is also a piece of crap even when compared to the Midland ER200.
My thought is if you need a cheap radio, buy a cheap one, the Kaito KA500L isn’t “cheap” although it straddles the line on price between cheap and not cheap. The Tecsun PL880 (expensive) also has a 18650 battery (but no crank or no solar etc etc) and is in my view is worth the extra money ($100 more so $59 vs $159) if you want a solid SHTF radio. At least you know it will work when you pull it out at a critical moment when it’s most needed.
toddcshoe
toddcshoe's picture
Last seen: 2 min 35 sec ago
The portables I have run on AA’s in the radio or a 6 volt wall wart. Well they run just fine on 5 volts so I took one of those Folomov A1 chargers I think, the one with the magnetic doohicky’s that stick to the battery, cut a USB cord off an old mouse, cut a plug off an old wall wart, little solder and heat shrink later, custom cable that will run my radios off any Li-Ion cell. I use high cap 26650’s for lots of runtime.
Side note, SW bands normally start at 1.8mhz and continue to 30mhz.
"Everywhere I go, there I am"
bikenber73
Thanks for the heads up I backed away from that Kaito brand. The good reviews seemed to be fake or from people who reviewed it by what it’s supposed to do not what it does.
bikenber73
If you have time could I get a picture of this invention?
Thanks
wle
wle's picture
Last seen: 4 hours 2 min ago
i have a decent one by lacrosse (though some of their other stuff is junk)
it probably isn;t available now
runs on 3 AA batteries
wle
--Daniel Behrman, "The Man Who Loved Bicycles".
--Greg Lemond.
              __o
    __o     _`\<,_      __o
  _`\<,_   (*)/ (*)   _`\<,_
whopist
Last seen: 2 weeks 1 day ago
I purchased this Midland ER200 NOAA Weather radio several years ago. It’s a very nice little “do all” portable radio.
Runs on a replicable 18650 battery
https://midlandusa.com/product/er200-compact-emergency-crank-weather-radio/
bikenber73
That one was on my list I seems nice . If the Sangean MMR-88 is a dud I might get it.
Thanks
Couchmaster
I paid $27.69 for the ER200 a couple years back. It’s worth that and it’s a nice little radio. Not worth $60. You can’t simply drop a regular 18650 battery into it, there is a special connector which must be on the battery, and that connector is difficult to insert into the mating part on the radio without needlenose pliers. I think that detracts a lot, if you pull the radio out when you need it most (say the power is out) and the battery isn’t connected or needs to be traded out, you need one with a connector soldered on already and even then you’ll be monkeyf**ing around in the dark with it for a bit. I wish they had just left the battery as a 18650 (no connector). Buying a spare battery for it is expensive.
To their credit, Midland makes that process look easy (bottom link below), but trust me, even a small child’s fingers won’t fit in there. Old arthritic fingers even less so. Midlands list price for that battery is and insane $25. If you had the connector fitting I suppose you would make it yourself.
https://midlandusa.com/product/batt26l-rechargeable-battery/
https://midlandusa.staging.wpengine.com/wp-content/uploads/2016/02/ER200-Battery-Installation-Instructions.pdf
toddcshoe
toddcshoe's picture
Thanks
Nothing fancy. This is the second one I made, kinda crude but functional. The other one is buried in my bag. I tried to use the Xtar PB2 charger/power bank but the radio doesn’t pull enough current to keep the PB2 on. It also works with one of those Li-100 chargers/power banks but it is a bit bulkier. The Folomov charging cable just fits in my bag better. Just had to make sure I had the polarity right on the plug for the radio. This radio requires center negative, but I can change the polarity of the plug by swapping the magnetic connections on the battery.
2019-02-28-12-32-37-349ss
Pete7874
Pete7874's picture
Thanks
The one Amazon review I read stated that the MMR-88 is a much better product than Midland ER200/ER210.
Lightbringer
Lightbringer's picture
Last seen: 56 min 17 sec ago
Boaz wrote:
They add endless needless worthless items to these radios to try to add value .( Where’s the seat belt cutter or the compass ) ?
This.
When I see a simple radio that includes a flashlight, powerbank function, bluetoof connectivity to play t00nz from your phone, other idiotic crap, that screams to me that the radio in general is garbage, and they add all that other garbage to “add value”.
What’s sad is that people buy into it… and buy it.
Lightbringer
If anyone cares, my “weather radio” is my scanner tuned with the NOAA freqs.
Miss the actual voice recordings, as the robots just sound creepy. “Uncanny valley”, and all…
bikenber73
Thanks
Great, now I understand. I have all of this
Thanks!
sb56637
sb56637's picture
Last seen: 1 hour 48 min ago
If you don’t care about AM radio I’d probably recommend a Baofeng UV-5R for ~$25. You can specifically enter any frequency, including all of the weather channels, plus the standard FM radio frequencies. Even comes with a (poor) flashlight. Smile Just program it to prevent it from transmitting if it’s not legal in your area.
