Sure I did a lot of research; how hot it should be, tools to use etc. And the new MCPCB surface text changed color due to too much heat.
But hey, gotta start somewhere. Lessons learned :student:
And now I have ordered a little 200W hot plate for future endeavors :+1:
So I got some Black Flatā¦ and a new Olight M22
So naturally, I measured the stock M22 : 2,9A and the advertised 23kCd from the XM-L2.
I swapped it for a BlackFlat, now it makes a nice 76kCd
While I was at it, I also put one in my GT Miniā¦ 4,5A and 220kCd, not as good as my D1S (260kCd) but the reflector is known to be far from perfect so Iām quite pleased with that result !
Firmware: TKās Anduril as modified by Pobel, with aux LED support.
Emitter Swap: two XPL HI 5D combined with two XPL HI 3D. Very bright and high output, without looking greenish like SST-20.
Main thing different between this and my last D4 mod was that I used 0.5mm Silicone sheet as the backing for the metal button boot. In my 2 prior builds I used 1mm thick Silicone sheet.
0.5mm thick Silicone sheet is thick enough for this purpose and allows the entire button boot to be thinner. With the new backing, the metal button is recessed below the level of the stock switch retaining ring, which further reduces the risk of accidental activation and makes it easy to find the button in the pocket.
The switch is not lit in this mod. Would be nice to do, but doing so is complex and would almost certainly result in the switch button being higher.
I broke my opus charger. The pin that goes into the charge port whe t to far and cracked the plastic(bottom picture). I cut of the 12v plug and solderd the cables straight to the board. The little pin inbetween red and black was connected in the original plug but i only had two wires and didnt really see the use for it. Does anyone know why its there? It works just fine now.
Last night I took a Lexel D4 aux board and manually replaced all 15 LEDs with different colored ones.
Those 0603 LEDs are absolutely tiny! Even with the fan on the hot air gun of my reflow station set to minimum it was still enough thrust to blow those miniscule LEDs right off the board from 6 inches away when they werenāt soldered on. After some trial and error, I finally got technique going where I held the LED in position with tweezers in my right hand while blowing hot air on it with the hot air gun in my left hand.
I played around with a couple of lights today, one for a buddy of mine and one for me. The friends light is a TK61, I put a White Flat on a 32mm MaxToch MCPCB in it. I had done a power boost to it some time back for him with a de-domed XM-L2 and he told me it was doing 575Kcd when he sent it to me. Today itās making 830Kcd at 5M indoorsā¦ too cold and yucky out for me to be doing a longer distance test. It makes 980 lumens using 2 30Qās in the 4 cell carrier. I think heās going to be pleased.
The other, my light, is a Convoy C8, a prototype in desert sand with a black coated metal button in the tail cap. Simon decided to make the production C8ās with rubber boots so this one is a bit different. Now itās even more different, it has a boost driver and XHP-35 D4 3A HI making 2139 lumens on a 30Q. I had to re-cut the driver shelf to accept a 20mm driver, instead of making a threaded retaining ring I made a slightly oversized brass press fit spacer to allow the battery tube to mate to it and press the driver in. Works nice, should serve to heat sink the driver via the tube. Love it when a plan comes together! I donāt have a lot of regulated lights so this one will be unique in that regard as far as my working collection goes. This oneās going to be getting a lot of use now for sure!
LOL, I remember that ledboard, still have 3 but never used them, I believe it was a scaru project, at least 4 years ago. Pictures of the build would be welcome of course.
Oh no, too expensive for a funny hot rod.
I have some SST40ās laying around and 7 good old XM-L
I used the 2oz chopper foil on OSH Park and the thinner board to improve heat dissipation.
And it is soldered directly to copper, of cause.
Yes I post them possibly tomorrow.
Now the head is in nitro-thinner.
The domes of the LED locked not well. They have had contact to my rasp as I wanted to make the aluminium pcb smaller to fit it to my copper heatsink in the skyray king.
And now they got hot from the bunsen burner.
4 LH351D 4000K 90+ CRI's on a MtnE quad, 10621 optic, UCL glass lens, 18 AWG wires extended for re-programming
CK driver designed for the ZY-T11 clones, RED aux LED w/10K resistor via a light pipe in the pill, Blue BeCu driver spring w/bypass
S2(+) alum spacer sanded down to fit, 1978 copper penny under the shelf, brass screws to secire down, MX4 between layers, MX4 for most of the MCPCB mount but Arctic Alumina thermal epoxy spot used to secure it in place and prevent sliding/movement
Tape used to center the spacer - centering had to be bout perfect:
What we do for lumens...
Pre-assembly parts:
CK's OSHPark driver, switch is surface mounted - extra solder in front and 2 part epoxy (clear) behind the switch for extra support:
Abe in the mounted position - 2nd picture shows the end of the light pipe in the upper right:
All done:
On a 25S at 4.19V, ~17.5 amps, 3929 at start, 3300 at 30 secs, 9.5 kcd (lumens in manufacturer lumens), great tint/beam
Thanx! $11 light, throw $40 in parts at it, hours of sanding/drilling/tap'n/soldering/wiring and you got something almost as nice as a FW3A or D4. These clones are a bit over sized for today, and the anodizing and threading isn't so great, but the clones are actually better quality than the original - clones have true alum reflectors while the original had plastic. For this one, the reflector had a hazy finish, pretty bad, so this mod worked out well for it. I do like the feel of the switch though on these - great for ramping
Yeah, I never got around to making an F13 into a triple. Thatās a nice beefy host, but works quite well with the stockā¦ āhostā? Replace the driver and emitter and it kicks arse. Or could. I donāt push mine terribly hard.
Dunno if you can get F13s as hosts-only, so you just buy a complete light and gut it. :laughing:
