Emergency Weather Radios
I pulled out my old Eton FR 300 and 400 after a few years of storage and found them covered in some sort of sticky film. It turns out that the plastic is breaking down. Its a common problem and Eton has a solution. Clean it with a decreasing product. Here
In doing this I broke a knob off :person_facepalming: So now I am looking for a new radio!
Anyone have one they recommend in the $25 - $30 range. My only real requirement is that it has WB and will pull in an AM/FM station. My Etons didnā€™t exactly have the best reception.
Thanks
Been there done that with Etonā€¦.aka ā€˜Grundigā€™ aka ā€˜Tecsunā€™. I got a PR-D4W Sangean and have never looked back, fantastic reception. Best WB capable portable I have ever used and heard.
I found at least one that runs off an 18650 but the old wire and special plug treatment was done to the battery so I cant simply pull one out and pop another in. I would have to attach the positive and negative wires to the 18650 if I wanted to change it.
I am digging this one quite a bit. Over my budget but I am thinking it might be worth it. It can run off any 18350! Any 18350 so thatā€™s good to know.
I wish there was one out there with everything built in, including a Micro SD or MP3 player for playing music from when there is no radio signals in the far back country. (with AM/FM Weather/SW, and rechargeable LiIon or external USB power.
Yea me to. I watched a review of this one and the only battery it operate off of is an 18350. I wonder why they choose the 18350, from the video it looks like there is plenty of room for an 18650 maybe 2.
I would have one in the mail it it ran off an 18650. I have a ton of those.
Still looking!
I bought a SAST N520 a while back.
It has AM/FM/SW / TF a LED light and it uses a 18650 battery and a USB charger.
For 12.68 it might be worth a try.
Mine works OK but not great, SW is pretty weak but I might just need a better antenna.
https://www.tmart.com/SAST-N520-FM-Radio-Mini-TF-USB-MP3-Speaker-with-LED-Flashlight-Red_p363126.html
:disguised_face:
(The elder has the right to chase after fashion!) :person_facepalming:
Nice find! Cool device. I love that it can use removable Li-Ion cells. I too wish it used 18650 instead.
Is the SW frequency the same or different from NOAA WX frequency?
Iā€™m not enough of a radio guy to tell you.
It goes from 700 to 1900 meters.
I donā€™t know how that converts to megahertz.
Sorry.
:frowning:
The standard NOAA channels are:
WX1 162.550 MHz 39B 7
WX2 162.400 MHz 36B 1
WX3 162.475 MHz 97B 4
WX4 162.425 MHz 96B 2
WX5 162.450 MHz 37B 3
WX6 162.500 MHz 38B 5
WX7 162.525 MHz 98B 6
The Google says that 162.400 + is VHF and doesnā€™t come in standard SW radios.
:frowning:
No - most SW receivers (or any other receivers unless specifically mentioned) do not cover NOAA WX/Weatherband.
These are 18650 powered.
This brand (Kaito) seems kinda of hit and miss.
https://www.amazon.com/dp/B07HPFTBV4/?coliid=I2HGXMT9V48NYI&colid=1DU8QV86H0E2G&psc=0&ref\_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B01I4W8EEE/ref=psdc_6893245011_t3_B0051QJJ1E
I ordered this one found one thatā€™s refurbished and guaranteed for 90 days . Iā€™ll just use it a bit to be sure itā€™s working. Maybe Iā€™ll buy an new JB 18350 light to go along with it next month.
Need a few more 18350ā€™s now!
Let us know what you think of it once you get it.
Sadly the new stuff is just junk . Grundig as well as other sold out and are now made poorly in china, Their name was bought or they just don't care any more . I have good old radios and wish for some added new technology added but who wants bad receive/poor sound quality and cheaply made junk that breaks after a few years . radio has followed in the Chinese footsteps of ( we can make it cheaper / work worse / break faster and you can sell your reputation, your good name and customer base down the river) . Short wave reception on these radios is a joke . They add endless needless worthless items to these radios to try to add value .( Where's the seat belt cutter or the compass ) ?
I'd like to modify a few older radios to run off of 18650's and add a charging circuit to the ones that take D size batteries .Plenty of room to work with. Generally I opt for radios that run on AA's since I have so many eneloop/rechargeables.
the internet killed radio
Let us know how you like it - Iā€™d be willing to bet you did well for the price.
I just bought the Kaito ka500L. Itā€™s unbelievably cheaply built and I wouldnā€™t get another. It looks great on paper. The L suffix is for ā€œLong Lastingā€. Basically itā€™s a ka500 with a 18650 battery for ā€œlonger lastingā€ LOL. They beefed up the solar panel as well which means instead of some marginal POS that doesnā€™t tread water, it will very slowly charge. I left mine in the window and it charged up from 3.702 volts to 3.76 volts in a couple of cloudy days. Which, by way of reference, is less than if you turn the crank handle 20 times. Regardless, at $50 itā€™s a very cheaply build product, the knob to select AM/FM/SW is poorly designed in that the choices are so close together that the cheap little POS plastic knob they use makes choosing channels a chore. The first one I got didnā€™t have the AM working, Kaito customer service was supurb and they quickly traded that one for one that was working. The builtin light is also a piece of crap even when compared to the Midland ER200.
My thought is if you need a cheap radio, buy a cheap one, the Kaito KA500L isnā€™t ā€œcheapā€ although it straddles the line on price between cheap and not cheap. The Tecsun PL880 (expensive) also has a 18650 battery (but no crank or no solar etc etc) and is in my view is worth the extra money ($100 more so $59 vs $159) if you want a solid SHTF radio. At least you know it will work when you pull it out at a critical moment when itā€™s most needed.
The portables I have run on AAā€™s in the radio or a 6 volt wall wart. Well they run just fine on 5 volts so I took one of those Folomov A1 chargers I think, the one with the magnetic doohickyā€™s that stick to the battery, cut a USB cord off an old mouse, cut a plug off an old wall wart, little solder and heat shrink later, custom cable that will run my radios off any Li-Ion cell. I use high cap 26650ā€™s for lots of runtime.
Side note, SW bands normally start at 1.8mhz and continue to 30mhz.
Thanks for the heads up I backed away from that Kaito brand. The good reviews seemed to be fake or from people who reviewed it by what itā€™s supposed to do not what it does.
