Interested in a 4-5000k one.
+1
More interested in the high CRI LH351D.
I’m interested in an SP36 with Anduril and an LH351D emitter. Don’t care about the glue.
5000K LH351D 80 CRI = probably buy
4000K LH351D 90 CRI = instabuy
Interested. This could be my first sofirn.
Interested !
Interested in 5000k
What about using long screws going down to the LED shelf without the extensions on the wall? Or using stand offs.
Then you can turn the head.
(Off course not as nice as extensions)
Interested! I was just looking into the SP36 but the emitters were putting me off. I haven’t used NarsilM yet but I’m trying to keep all my UIs the same so Anduril is a bonus
Would the LH351D be super floody? I personally like something with a bit more throw, like XPL-HI or SST. Either way, definitely nothing with a green tint. As others have mentioned, no glue would also be very welcome.
How is the charger and cover in the SP36? Any need for improvements here?
If any body changes are to be made may I suggest a nice matt black finish with no branding? I seem to recall Sofirn omitting branding recently but can’t remember which model it was for (EDIT: it was the SP36).
Interested in LH351D 4000K 90 CRI, I might also buy one if it’s 5000K. Regarding the glue, I think it doesn’t matter too much since it will be coming with desired emitters.
Edit: 219C 4000K 90 CRI/ 319A 4000K 80 CRI is also a nice choice, but 219C is more expensive, and maybe it is harder to source 319As?
Interested
I would like a choice between emitter and tints like Convoy, Emisar, and Fireflies have been giving us, but if that’s not feasible I’d settle for 4000k or 5700k that was discussed earlier.
Intrested also
Me to …… interested
good news, sofirn find good Samsung supplier.
这是个好消息, Barry! :THUMBS-UP: If you are able to source LH351D 5.000K 70CRI (W6 Flux Bin) for ultimate performance (approx. 500 lumens less than or equal to original XP-L2 configuration) and LH351D 4.000K 90CRI for best colour rendition you would make a lot of BLF members happy. :-)
Two suggestions from my side:
- Please don't use glue on the SP36. It's a nightmare to pull out the driver. It took a 3000°C blowtorch and a lot of strength to loosen the driver enough to get it out.
- Please check those stainless steel countersunk screws on the negative pole disc that retains the springs. All current needs to run through these little screws causing a major bottleneck (in numbers you loose about 500-1000 lumens incl. bypassed springs). The disc should better be deanodized.
@Lux-Perpetua, did you have to use an acetylene blowtorch?
Because if that is, it is insane.
If so, I would just an RSU unit to melt the glue.
A friend of mine did this amazing job. He told me he used an ethyle welding torch for it. It was a real mess to get rid of all these solder residues from the brass ring afterwards. There was no way of pulling it out like Djozz did or by attaching a cable with two solder joints to pull on it.
I’m interested
Is there a more mod-friendly adhesive that can be used? If it’s only to stop the driver falling out when the battery tube is removed it doesn’t need to be that strong.
