I don’t think it’s all that much brighter either. I got mine last Saturday and have been doing some more comparisons at different distances and in different environments and I don’t think it’s as bright as they say. When I compare my 130 lumen energizer to the Sofirn SF13 in turbo mode, it’s about twice as bright, which would put it at 260 or maybe 280 lumens. Even if it was 320 lumens, it’s still 100 lumens lower than what the unit I have is advertised as. I think I either got the older version, or the 420 lumen figure is based on using 14500 cells instead of AA, even though they specify AA.
I know I’ve read somewhere around these forums that perceived brightness doesn’t correspond consistently with actual lumen output. Stuff like how a light that’s technically twice as bright as another only appears 1.5x as bright, or something like that. So it could actually be outputting closer to 420lm, but only appearing twice as bright as 130lm rather than three times as bright.
Using 14500’s in the SF13 will likely result in magic smoke since the driver is rated at 1.6 to 3.2v. Even a single 14500 with a dummy cell will be over the rated voltage so I highly doubt they used 14500’s in their rating.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
I guess I won’t be trying that then. I’m using 1.2V NiMH batteries instead of 1.5V alkalines. I haven’t tried alkalines yet, but maybe I should do it to compare if they’re a bit brighter due to the 2 alkalines having a combined increase of .6 volts over the NiMH.
See, alkalines have very high internal resistance.
That means for anything over 50-100mA, they lose a ton of capacity and a lot of power.
Also, their discharge is more of a linear curve, as they fall very quickly down from 1,5V, while NiMH stays at 1,2V average voltage for the entirety of the discharge.
TLDR: LSD NiMH cells crush everything alkaline does, even matching it in long term self-discharge.
This explains why my digital camera actually works with NiMH batteries while alkalines won’t work for more than a couple minutes after putting fresh ones in the camera. The alkalines still test as very good, but my camera sees them as dead.
Phlogiston:
Could you please tell me how to turn the light on in low mode? The instructions say that “fast clicking” it on from when its off activates memory mode and turns it on in the last mode it was in. But for me, it comes on in the last mode it was in no matter how slowly I turn it on. Sometimes I want it to come on in low mode, but comes on in turbo if that’s what I last used.
The second unit I received had more glue inside and was a lot harder to open.
Just received two SF13 “420 lm version” (ordered during the spring sale for giving away to friends). And I can report that the bezels on these two units aren’t glued.
Phlogiston:
As far as I know, there’s no short cut to low. The light always uses mode memory.
The manual’s not very good, shall we say. Just as an example, the German part of my manual actually refers to a completely different light!
16mm vr16 mcpcb from virence.com. I buy them presoldered. It fits the sf13 and sf14 v1 but does not fit the sf14 v2 because they decreased the mcpcb to I think 15 or 14 cm. Too bad the sf14 v1 not available anymore.
You could be right.
They won’t be brighter, at all.
Phlogiston:
good small light, i bought one last month, and it update to 420lm already
Sofirn official Store-Aliexpress
Wholesale/Agent/OEM/ODM-Alibaba
Facebook
Bezels arent glued. I modded three of them last week with e21A 9080 and Optisolis. Works well except I dont like the UI as much as the SF14
Which PCB are you using for those mods? Is that for both the SF13 and SF14?
What are you using for an optic/reflector, and does it work reasonably well with the Optisolis?
If you’ve come up with a good combo, this seems like a cost-effective way to get rare emitters into practical lights.
