Thatâs the difference between these two control ring lights.
V11R has to be flipped or hand hold changed to hit the switch but remains at what ever level the control ring is set to.
RRT01 doesnât require anything but the turn of the ring for on and off but always starts in moonlight, no memory so to speak.
Each design has its own advantages. V11R on/off is tail switch controlled, so your hand will be in a specific orientation. You then have to change it to adjust intensity (or use your other hand). But then you have on/off control with a fixed output. RRT-01 has only one control, so youâre always holding it in one orientation for on/off and intensity. If youâre used to having a sequential set of fixed brightness levels, itâs a very different feel. Some people may simply not like it.
for those who dont like KISS, there is also the HDS RotaryâŚ
has a tailswitch, and a Rotary dial at the tail (flipping optional, I do),
its regulated, has memory, and can be programmed for fixed brightness levels tooâŚ
for people that can live without a deep carry pocket clip,
and get turned on by reading manuals about multi-clicking
Haha, I was being more sarcastic than anything. Who would have thought to look at Battery Junction when the info should have been in the OP? If it turns out to be an xpg3, I wonât order it. Isnât that the old version at BJ and in the OP?
Those slots are 12 mm long? I was think'n they were for the std 1.5x6 mm size, but from the pics, they have to be longer than 6 certainly, so probably the 12 mm size you ordered.
