for those who dont like KISS, there is also the HDS Rotary…
has a tailswitch, and a Rotary dial at the tail (flipping optional, I do),
its regulated, has memory, and can be programmed for fixed brightness levels too…
for people that can live without a deep carry pocket clip,
and get turned on by reading manuals about multi-clicking
Haha, I was being more sarcastic than anything. Who would have thought to look at Battery Junction when the info should have been in the OP? If it turns out to be an xpg3, I won’t order it. Isn’t that the old version at BJ and in the OP?
Those slots are 12 mm long? I was think'n they were for the std 1.5x6 mm size, but from the pics, they have to be longer than 6 certainly, so probably the 12 mm size you ordered.
Not without grinding. Best I can tell the slots are 2.25mm in width. Seems they intended the slots to fit 2x10mm but the 2x12mm is more common at our usual oversea’s stores.
