As said above, there isn’t really going to a throw/flood option, they are all “floody”. I think the SST-20 would be a great option. I honestly might even prefer it to the LD, depending on how much lumen difference there will be.
Doesn’t really matter if it’s using an SST-20 setup, or an LH351D setup.
In a light with such small TIR optics, more throw is always beneficial, so an SST-20 option would be great, especially since it has even better R9 in the CRI spectrum.
I do prefer using the LH351D in lights like the BLF Q8, but for the FW3A?
It’s all a matter of personal taste. But I find that LH351D is just a bit too floody for me. I much prefer the extra punch of XPL HI or SST 20.
I expect when I get my FW3A I’ll probably swap out the emitters for XPL HI (probably two 5000K and one 4000K) and the optic to 10507.
SST 20 is nice, but I find it looks a bit too green-tinged. Also compared to XPL HI, SST 20 with its lower Vf it draws more current which causes the head to heat up faster resulting in the driver ramping down output faster.
That’ll produce a pretty strange beam pattern. XP-L HI + 10507 tends to have fairly visible artifacts, and you’d be getting artifacts in two different colors.
That might be exactly what he’s going for. Look at his username. Maybe he’s going to run it on candle mode and watch the artifacts flicker all over the place. :partying_face:
No need to consider protected cells, just unprotected button- and flat-tops. It seems that this model has limited its ability to accommodate a range of cells by using a short set of springs. Resistance shouldn’t be the reason - this light should draw substantially less current than the Emisar D4, which accommodates both flat- and button-top cells pretty well.
It seems like a lot of people on this thread have said they want the SST-20.
My preference would be the SST-20 as well as long as it’s high cri and as close to the BBL as possible. Especially if picking this led over the LH315D would speed things along.
Had to laugh, I said something similar long ago: I'm no Modder, but I can Solder. NovaTac 120 Upgrade! | Candle Power Flashlight Forum! (warning: off-site link)
That single mod really led to a big lifestyle change. Here I am nearly 10 years later waiting for yet another rear-mounted e-switch light that will inevitably get modded at some point.
Been a while since I logged in, saw 40 posts in this thread and thought “maybe?….”. Nope. That’s OK, I’m patient. I put an arbitrary annual flashlight limit on myself and the FW3A will be IT for the year. If it isn’t ready to ship by December I’m sure there will be some other light waiting to fill the 2019 quota.
hm i dont get it, suddenly there is a problem getting the LH351D emitters when they were confirmed long ago, so they will change to sst20 now then or ?
Actually, I modded lights with mixed emitters and the Carclo 10507 years ago. Before quads were common, the big thing everyone modded were triples and I converted numerous lights to them including the Sunwayman C20C, DQG Tiny III, and Convoy S2+.
When you mix emitter tints in these small triples the hotspot and most of the spill is a completely uniform mix with no artifacts that perfectly blends the emitters into a uniform new tint. You don’t even notice that different emitter tints were used unless you turn the light on in moonlight and look into the bezel, or shine it on a white wall from an inch away. Even from a foot away the beams blend almost perfectly. Not suprising since the hotspots are probably a foot wide and the emitters are maybe 1 cm separated.
The only artifacts the 10507 produces are a ring of flower petal like shapes at the edges outside the beam. These petals come from individual emitters so will be different colors and won’t blend. But the reality is they aren’t really noticeable except when looking at a white wall and spinning the light like a pinwheel in your hand. They also don’t look at all ugly.
Toykeeper just said that she thought they put the order in a long time ago, but it turns out they didn’t. Now they are trying to order them and are having problems getting the exact tint, etc… So it seems Lumintop made a mistake by not ordering soon enough.
Now we are in a position where they can put their order in now and it will be a long time before they can get them or maybe they will just order the sst-20 and maybe get it sooner. Make sense?
