I'm so glad Thorfire/Sofirn stayed with what we recommended for Q8 specs. Reading the reviews, the 2 big things they like is the brightness and that the lumens rating is honest, and generally they love the UI. There's also the quality and chunkiness - feels like it's built solid, which it is of course.
I like what they did with the Sofirn Q8 version - the battery tube design and the XPL HI's.
What I'd like to see is more LED and body color choices, better anodizing, possibly a higher quality double coated AR lens, and USB-C charging.
Watch for your name to be added to the list of names at the bottom of the first post in this thread. It is sometimes quicker to go to the second post and scroll up.
new detailed drawings are in for the build design, and it is looking good. (only the production model will have the same battery tube as the Sofirn Q8 with no flats) It will have the charging port with a rubber seal cap on the back 180 degrees from the switch side.
Just a heads-up that the updated lists will usually be pushed to the cloud each Sunday night. Updates to post number 2 will likely be shown shortly thereafter.
Everyone should check the names list to verify that their BLF name is correctly spelled. Names are not case sensitive but otherwise your name must correspond exactly to what is on the list. Note that embedded spaces are valid characters and must be the same in both cases. So for example if your name is ‘XXX YYY’ with 1 embedded space and ‘XXX YYY’ with 2 embedded spaces is on the list then they are not the same.
The reason why this is important is that the pm’s will be generated from the names shown on the list (many thanks to Mr.Scott for the script!). If your name is not on the list then you won’t be getting a pm in the future.
This is a 1 time only check. Once verified that it is right then that’s all the checking needed. If your name needs to be corrected or added then send me a pm. Do not post in this thread what the correction is since it could easily be missed.
