*BLF LT1 Lantern Project) (updated Nov,17,2020)
I shouldn’t, but I’m going to, put me down for a second one as well. I’m already down for one, so make it two please.
Interested
Yeah I think I need to make my 2 into three.
2 for in the house, and one for in the car. Just seems like it might be a good thing to have in case a sustainable light is needed.
Count me in. I'm new to this, so how do I know I made the list in time?
^ you are in plenty of time to make the list, Welcome to BLF!! :beer:
Me too please!
You are in time.
Watch for your name to be added to the list of names at the bottom of the first post in this thread. It is sometimes quicker to go to the second post and scroll up.
Some updates from Barry and the manufacturer!
new detailed drawings are in for the build design, and it is looking good. (only the production model will have the same battery tube as the Sofirn Q8 with no flats) It will have the charging port with a rubber seal cap on the back 180 degrees from the switch side.
Looks great Den. Thanks for posting this. Going to be a handsome lantern
Just a heads-up that the updated lists will usually be pushed to the cloud each Sunday night. Updates to post number 2 will likely be shown shortly thereafter.
Everyone should check the names list to verify that their BLF name is correctly spelled. Names are not case sensitive but otherwise your name must correspond exactly to what is on the list. Note that embedded spaces are valid characters and must be the same in both cases. So for example if your name is ‘XXX YYY’ with 1 embedded space and ‘XXX YYY’ with 2 embedded spaces is on the list then they are not the same.
The reason why this is important is that the pm’s will be generated from the names shown on the list (many thanks to Mr.Scott for the script!). If your name is not on the list then you won’t be getting a pm in the future.
This is a 1 time only check. Once verified that it is right then that’s all the checking needed. If your name needs to be corrected or added then send me a pm. Do not post in this thread what the correction is since it could easily be missed.
Do not send me a pm if your name is correct.
Thanks
Thanks for the info. send along the added names in a PM after the Sunday updates so i can update the OP.
Will do….thanks!
I’m nr. 900 on the list. Please put me in for two more.
Looks great! Will it have powerbank function so it can replace my Goal Zero Lantern?
Also has the emitters been sourced or determined?
No powerbank function, as it would make the build more complicated for the V1.
The emitters have already been determined to be 2700k LH351Ds 90CRI and 5000K LH351Ds 90CRI.
Because of tint mixing, the light emitted will be below the BBL curve by a long shot, especially closer to 2700k.
I am # 237 and 238 on the list. Please put me in for two more.
Thank You
Looks really good. What are the next steps? Still on Sofirn to produce a prototype?
Looking good sofar, but I will have a closer look tonight. I like the slightly rotated T in the switch button, just like most of my Q8’s :smiley:
Please add me another unit.
They have to use up those Thorfire buttons! :stuck_out_tongue:
