Count me in. I'm new to this, so how do I know I made the list in time?
^ you are in plenty of time to make the list, Welcome to BLF!!
Me too please!
You are in time.
Watch for your name to be added to the list of names at the bottom of the first post in this thread. It is sometimes quicker to go to the second post and scroll up.
Some updates from Barry and the manufacturer!
new detailed drawings are in for the build design, and it is looking good. (only the production model will have the same battery tube as the Sofirn Q8 with no flats) It will have the charging port with a rubber seal cap on the back 180 degrees from the switch side.
Looks great Den. Thanks for posting this. Going to be a handsome lantern
Just a heads-up that the updated lists will usually be pushed to the cloud each Sunday night. Updates to post number 2 will likely be shown shortly thereafter.
Everyone should check the names list to verify that their BLF name is correctly spelled. Names are not case sensitive but otherwise your name must correspond exactly to what is on the list. Note that embedded spaces are valid characters and must be the same in both cases. So for example if your name is ‘XXX YYY’ with 1 embedded space and ‘XXX YYY’ with 2 embedded spaces is on the list then they are not the same.
The reason why this is important is that the pm’s will be generated from the names shown on the list (many thanks to Mr.Scott for the script!). If your name is not on the list then you won’t be getting a pm in the future.
This is a 1 time only check. Once verified that it is right then that’s all the checking needed. If your name needs to be corrected or added then send me a pm. Do not post in this thread what the correction is since it could easily be missed.
Do not send me a pm if your name is correct.
Thanks
Thanks for the info. send along the added names in a PM after the Sunday updates so i can update the OP.
Will do….thanks!
I’m nr. 900 on the list. Please put me in for two more.
Looks great! Will it have powerbank function so it can replace my Goal Zero Lantern?
Also has the emitters been sourced or determined?
No powerbank function, as it would make the build more complicated for the V1.
The emitters have already been determined to be 2700k LH351Ds 90CRI and 5000K LH351Ds 90CRI.
Because of tint mixing, the light emitted will be below the BBL curve by a long shot, especially closer to 2700k.
I am # 237 and 238 on the list. Please put me in for two more.
Thank You
Looks really good. What are the next steps? Still on Sofirn to produce a prototype?
Looking good sofar, but I will have a closer look tonight. I like the slightly rotated T in the switch button, just like most of my Q8’s
Please add me another unit.
They have to use up those Thorfire buttons!
We are discussing the test-build unit now in the team chat for a test prototype before the production for the first group buy orders are ready.
Ok, I had a better look at the design. Some commends:
*the driver section is still pretty massive, and so is the top section. If the coming prototype feels overweight, some grams can be spared by making the driver section leaner here and there, and changing out some of the solid aluminium in the top section for a finned section (vertical fins I think), good for heat dissipation too, and it looks good.
*the light cup seems one piece with the bottom and central tube of it, right? And it will be made of frosted plastic I assume? It would help extracting the light if the central tube plus the bottom of the light cup has a mirror finish, like flashlight reflectors have. But it would become a rather difficult plastic piece like that.
*the way the top is screwed on here, the complete force of the screw is transferred to the plastic cup. Overtightening the screw will crack the cup. This can be improved by inserting a metal (alu) tube of the correct length into the central tube of the light cup, so that the screw tightens the metal tube between top and driver section (the ledboard needs a larger hole in the middle to make room for the tube), while pressing the plastic light cup mildly into the o-rings on top and bottom. That tube can be shiny on the outside if the lightcup itself can not be made reflective there.
I can not see where the led wires go from driver to ledboard, that could interfere with such a metal tube, but it seems to me that a solution can be found for that.
If I come up with more, I will annoy you with that again.
As for the mid section its shorten a little from the one i built originally, (also were looking at a version-2 later down the road to add the powerbank feature, that will likely need the extra space and aluminum there for heat dissipation was the thought for having a bit of “beef” left in that area.
- As for the globe/lens part it will be likely a one-piece tougher medium-frosted plastic (like polycarbonate if possible) and the center will be using a white sleeve/cup to cover it and the bottom inside, preferably matte/flat white, and not shiny chrome as i have tested shiny mirror surfaces and all that does is cause sharp eye glare, artifacts in the light distribution and very little to increase light reflection or smooth out the light emitted.
As seen in the image below:
for the third question, if the globe/cup is made from polycarbonate, it will be very strong, ( even if Acrylic is used and the walls are made thick it should be strong enough to withstand a good pressure. ( preferable polycarbonate (lexan type material though)
The wire leads will run to the LED MCPCB inside the center tube along side the center bolt.
