I currently have a few big lights that each cover a rather specific category:
DX80 extreme output - high flood - medium throw
MF04 low output - no flood - extreme throw
MT03TA extreme output - extreme flood - no throw
The GT & MF04 created a new category of extreme throw - low output/flood
The GT70 & R90C created a new category of high throw/output - mild flood (due to spill)
-I donât personally consider the MF04S in the above category given itâs reported less than 1 minute runtime on turbo. otherwise sure itâs in.
The GT4 looks like it could amplify the high throw/output - mild flood category into extreme throw/output - medium flood (due to spill)
The DX80, X80GT, MS12 & X70 are just output monsters with no realistic throw in comparison to the new 1 000 000+ cd category. The X70 makes only 311kcd and has extremely small reflectors so to me the MF03 looks kind of in between with itâs deeper smooth reflectors was my guess. Maybe like a DX80 with extra throw?
Anyway⌠Iâm stoked for the GT4 whenever it eventually comes out. I really like the idea of a mild/medium flood, huge hotspot, mega thrower! My MF04 is crazy but in the dark I basically canât see where Iâm walking. My DX80 is also crazy but using turbo in the winter basically blinds me due to the sheer amount of light reflected back at me off the snow
Or maybe it just looks cool and Iâm good at rationalizing why I need more super expensive toys! :person_facepalming:
do we actually have any beamshots or info about lumen output, runtime and temperature of the GT4 or are we just speculating and waiting for it to be released?
Texas_Ace has a prototype and the lumens numbers are as tested by him, there are some revisions to smooth out details but other than that the functioning light has been tested.
I did get a prototype in and have tested it but it has issues so I have not made the tests public yet until I know how they will be fixing them.
I can say the thermal performance is the best I have ever seen, With this much power it will still have to step down the output of course but it heats up surprisingly slowly considering the power. I am very pleased with the thermal performance.
The output is also good but sadly the LEDâs died during disassembly/reassembly so I am unable to test it properly until I get replacements. They should be in next week.
Based on basic math though, 20k lumens is a very reasonable number I expect. The MT09R with 3x xhp70.3 and only 4 batteries can do ~18k lumens, so with 4x XHP70.2 and 8 cells it is not a big leap to assume that 20k lumens is well within reason assuming they get some good bin LEDâs.
well in theory maybe yes, since this light will have no active cooling i think going over 20k is not needed imo. Better if they keep around that mark and make it run as stable as they can before thermal stuff does the job and steps down, but this is just me guessing unless lumintop wanna compete with acebeam and imalent in lumens war⌠Just looking at the few images posted i can imagine even at 20k lumens or so it will be an impressive light with 4 deep reflectors pushing what 1km throw or something ?
How are you going to limit the current of a FET driver?
Unless the driver is a buck+FET driver, you wonât be getting less than 20k lumens in this light, personally knowing itâs going to be in the real of 28k lumens+ instead.
Indeed, with 8x18650s and dual silver plated BeCu springs in the carriers, and a thick short dual silver plated dual BeCu springs, current is going to go amok.
Kinda sorta. You never get exactly 4x the output due to resistance and other factors but yes, it is safe to say I am being conservative in my 20k+ lumen estimate.
You can limit output on an FET driver by simply limiting the max PWM. The efficiency difference is surprisingly small vs a buck driver at high PWM levels.
OR, use lesser cells to limit output⌠like a Panasonic B vs a Samsung 30Q. Availability of amperage will be a deciding factor to a degree, setting PWM values lower will take it further.
In my own experience heat at the emitter shelf will be a deciding factor when utilizing multiple 70.2 emitters, while a single 70.2 can indeed be run pretty hard the accumulated heat of multiples tends to knock out individual dies in the 4 die array causing failure. This light is designed to handle quite a lot of heat, remains to be seen if all 4 emitters can handle the output of quality cells over extended times of full Turbo operation.
In my own builds I have found it can be exasperating having these die failures, losing one, two, then all 4 dies and having to replace the big emitters. So yes, I am very interested in seeing how this goes⌠given I can even afford this light I will plan to find out for myself how it performs. I DO like how itâs made and give Kudoâs to Lumintop for their efforts.
I donât think this light will suffer too much from heat build up in the head. The mcpcb is the largest I think that has ever been used in a flashlight and the surface area on the head is amazing as well.
I bet the surface area per LED is pretty close to the GT70 for itâs single LED.
lol, very true, it will of course overheat in that case if thermal control is turned off. Although I am interested in trying this myself once the replacement LEDâs come in. The GT70 peaked around 90-95c, I am not sure what the GT4 will peak at.
