My favorite, and many other’s as well, is also XPL-HI. I think some people want to just try another emitter, or keep the cost slightly lower. I’m sure I’d be very happy with just two XPL versions.
3D and 5D XPL HI are great options. Hank's been selling the 5D's for quite a while now, but who knows if they are still available in the supply chain.
The LH351D's are exciting for being high CRI and good lumens, while the SST-20's are exciting for super high CRI, decent lumens and better throw. The benefits though aren't overwhelming, but they also come with cons. So far I'm lik'n the 3500K SST-20's from Blue, but my prefs are on the warmer side of neutral anyway, and not sure if I'm susceptible to noticing the greens as much.
Actually bugger it - I’ll put myself down for another (now total of 2) - one of each option
I’m interested in one!
I am interested in one, please.
Not exactly new news but the LH351D 4000Ks is currently out-of-stock from their usual China suppliers and with no definitely timetable for availability,
the SST20 4000k is being considered.
In the meantime, guys let’s enjoy our OTHER lights.
Couldn’t they just order LH351D emitters outside of China?
Or do they not want that?
Obviously Lumintop (or any company for that matter) can but I don’t want to speculate on that.
No problem.
Thanks a lot for the updates still!
:+1:
But a light like this, aren’t all the emitters just tied in parallel, with nothing to balance the current? Mixed emitters would likely have varying forward voltages, which means that the lower Vf device would tend to hog the current.
Yes… but usually this is not a problem when mixing the same type of emitter in different tints. They have the same Vf.
I’ll take two.
One of each led set.
One of each finish.
Preferably ‘clear’ anodized aluminum over raw.
Nice job Fritz & team !
I’ll take two.
One of each finish.
Preferably ‘clear’ anodized aluminum over raw.Nice job Fritz & team !
There is only one finish. No clear/raw. Just the darker gray.
Please put me down for 1. Thank You.
I’d like one please. Thank you
>>>LH351D may happen a few weeks after XP-L HI, due to lead time in sourcing parts.
>>>Anodizing is dark grey.
>>>Unanodized bare aluminum might happen later, but this isn’t determined yet. <<<
I am simply saying that I would like to show interest/buy a second FW3A in a finish of raw/clear aluminum if/when available.
I did this with the FireFlies E07. 1st a Grey anodized XP-L Hi 5000K at release.
Then got a clear aluminum (SST-20 4000K Hi CRI) when that finish option came out later.
Okay, but raw/clear aluminum is not part of this group buy.
I send my Proto4 to my friend Andreas for beamshots.
Thank you Andreas for your great work.
Thank you Andreas for your great work. :+1:
Thanks Bluzie and Andreas! It surely shows how the beam looks like, and i’m liking it
BTW, that is with a 10508 Carclo, not the originally intended 10511 which will give a different beam with more hotspot, not so wide!
I do like it this way too, though as there are no beam artifacts
