Please put me down for 1. Thank You.
I’d like one please. Thank you
>>>LH351D may happen a few weeks after XP-L HI, due to lead time in sourcing parts.
>>>Anodizing is dark grey.
>>>Unanodized bare aluminum might happen later, but this isn’t determined yet. <<<
I am simply saying that I would like to show interest/buy a second FW3A in a finish of raw/clear aluminum if/when available.
I did this with the FireFlies E07. 1st a Grey anodized XP-L Hi 5000K at release.
Then got a clear aluminum (SST-20 4000K Hi CRI) when that finish option came out later.
Okay, but raw/clear aluminum is not part of this group buy.
I send my Proto4 to my friend Andreas for beamshots.
Beamshots from Andreas
Thank you Andreas for your great work. :+1:
Thanks Bluzie and Andreas! It surely shows how the beam looks like, and i’m liking it :wink:
BTW, that is with a 10508 Carclo, not the originally intended 10511 which will give a different beam with more hotspot, not so wide!
I do like it this way too, though as there are no beam artifacts :wink:
Wow, the gray anodization has a bit more blue in it than I realized.
Maybe these pictures were taken under a bright light. (Probably, maybe it’s due to a certain temperature of light that adds a blue tint)
Perhaps the blueish tint is most probably the result of lighting (which affect the tint of the gray finish) when the photos were taken.
I have posted this photo elsewhere, and as an example of that effect, to show the change of gray to blueish, of the same light and time of photo-taking ( the right photo is the real gray finish of the Avaritia NA40SE) are the photos below:
More photos from this thread: HERE
Certainly not being the best person to brag about his photographic skills,
but I think that every person involved has shown us a photo with a different color of ano.
And I can’t imagine that LT fills a fresh bath of ano for every copy they send.
Is it possible to send one of the last specimen to a professional photographer, like DBCustom?
Or is it advisable to publish only photo’s of the FW3A in the company of well known lights?
/\ … THIS … /\
Agreed, thanks tatasal. . :+1:
They don’t do this themselves. It’s outsourced, afaik.
The exact color doesn’t matter to me. They all look good. :partying_face:
Amen!! . :+1: . :beer: :beer:
yes i agree with others all colors so far looks good.
Regarding emitter options: I’d actually prefer SST-20 over LH351D in this light. In fact, I’ll be installing some regardless. I know that means my vote shouldn’t count for much, but at least consider my reasoning.
It’s true that the SST-20 are dimmer than either the LH351D or the XP-L HI, and almost certainly have worse tint than the XP-L HI. However, let’s not get bogged down with comparisons to the XP-L HI since that’s an excellent choice and is getting produced either way. And the SST-20 isn’t going to have significantly worse tint than the LH351D; they’re both known to have fairly green binning on average if you don’t shop carefully.
The LH351D is a much floodier emitter than theSST-20 (which throws more like the XP-L HI), and in an already-floody 20mm triple TIR it’s going to be wasteful. You’re going to need to run a higher brightness level to light up a particular distance away. The SST-20 is much less efficient in an integrating sphere, but especially in a ramping light you aren’t going to ramp up to the same number of lumens on both options and then complain about how much hotter the SST-20 is getting - you’re going to ramp to the same number of lux on a particular target, because that’s the brightness you can perceive. And the SST-20 will be using less power than the LH351D to get there, not more.
If you care mostly about tint and efficiency, the XP-L HI is still your choice. But if you’re concerned more with CRI (especially R9), in actual use the SST-20 is a great option. I’ve got them in my Emisar D4 and their tight beam makes the light far more useful than the numbers would suggest. And, for a back-to-back comparison, I pulled the SST-20 out of my D4S and installed LH351D’s, because in that larger head they were too focused.
I like the beamshots with the 10508 Carclo a lot. I will mostly use this light to light up thing close distance. So a very evenly floody beam would be nice.
So i hope they can get the LH351D. And i will most likely try to change the optic to a 10508 or something similar.
Here’s a calibrated photo of the FW3A. Used the X-rite colorchecker passport to generate a .dcp color correction profile for the Viltrox LED panel and Panasonic DMC-GM1 mirrorless SLR. It’s not as blue as the previous photo would suggest. Very slight bluish shift on the grey.
Thanks maukka, nice work & pictures!! . :+1: . :beer:
Of all the 50 shades of grey, this is a particular nice one!
Thanks maukka :+1:
+1 awesome stuff :+1:
That looks so smart. Can’t wait to get mine
