13583 posts / 0 new
oweban
oweban's picture
Last seen: 1 hour 12 min ago
Actually bugger it – I’ll put myself down for another (now total of 2) – one of each option Wink
f0xx
f0xx's picture
Last seen: 1 week 6 days ago
I’m interested in one!
hugh
Last seen: 9 months 3 weeks ago
I am interested in one, please.
tatasal
Last seen: 1 min 47 sec ago
Not exactly new news but the LH351D 4000Ks is currently out-of-stock from their usual China suppliers and with no definitely timetable for availability,
the SST20 4000k is being considered.
In the meantime, guys let’s enjoy our OTHER lights.
Beer
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 59 min ago
Couldn’t they just order LH351D emitters outside of China?
Or do they not want that?
tatasal
Obviously Lumintop (or any company for that matter) can but I don’t want to speculate on that.
BlueSwordM
No problem.
Thanks a lot for the updates still!
tatasal
BlueSwordM wrote:
No problem.
Thumbs Up Beer
funkychateau
funkychateau's picture
Last seen: 7 months 2 weeks ago
Firelight2 wrote:
DavidEF wrote:
ToyKeeper wrote:
Firelight2 wrote:
XPL HI (probably two 5000K and one 4000K) and the optic to 10507.
That’ll produce a pretty strange beam pattern. XP-L HI + 10507 tends to have fairly visible artifacts, and you’d be getting artifacts in two different colors.
That might be exactly what he’s going for. Look at his username. Maybe he’s going to run it on candle mode and watch the artifacts flicker all over the place. Party
Actually, I modded lights with mixed emitters and the Carclo 10507 years ago. Before quads were common, the big thing everyone modded were triples and I converted numerous lights to them including the Sunwayman C20C, DQG Tiny III, and Convoy S2+.
When you mix emitter tints in these small triples the hotspot and most of the spill is a completely uniform mix with no artifacts that perfectly blends the emitters into a uniform new tint. You don’t even notice that different emitter tints were used unless you turn the light on in moonlight and look into the bezel, or shine it on a white wall from an inch away. Even from a foot away the beams blend almost perfectly. Not suprising since the hotspots are probably a foot wide and the emitters are maybe 1 cm separated.
The only artifacts the 10507 produces are a ring of flower petal like shapes at the edges outside the beam. These petals come from individual emitters so will be different colors and won’t blend. But the reality is they aren’t really noticeable except when looking at a white wall and spinning the light like a pinwheel in your hand. They also don’t look at all ugly.
But a light like this, aren’t all the emitters just tied in parallel, with nothing to balance the current? Mixed emitters would likely have varying forward voltages, which means that the lower Vf device would tend to hog the current.
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 8 min ago
Yes… but usually this is not a problem when mixing the same type of emitter in different tints. They have the same Vf.
Flash Foto
Flash Foto's picture
Last seen: 1 year 1 month ago
I’ll take two.
One of each led set.
One of each finish.
Preferably ‘clear’ anodized aluminum over raw.
Nice job Fritz & team !
"Let there be light" is an English translation of the Latin phrase fiat lux.
JasonWW
JasonWW's picture
Last seen: 54 min 58 sec ago
Flash Foto wrote:
I’ll take two.
One of each finish.
There is only one finish. No clear/raw. Just the darker gray.
TylerDurdenThree
Last seen: 1 day 5 hours ago
Please put me down for 1. Thank You.
Lights, Lights, Lights
Maxxsounds
Last seen: 4 hours 27 min ago
I’d like one please. Thank you
Flash Foto
>>>LH351D may happen a few weeks after XP-L HI, due to lead time in sourcing parts.
>>>Anodizing is dark grey.
>>>Unanodized bare aluminum might happen later, but this isn’t determined yet. <<<
I am simply saying that I would like to show interest/buy a second FW3A in a finish of raw/clear aluminum if/when available.
I did this with the FireFlies E07. 1st a Grey anodized XP-L Hi 5000K at release.
Then got a clear aluminum (SST-20 4000K Hi CRI) when that finish option came out later.
cabfrank
Last seen: 2 hours 5 min ago
Okay, but raw/clear aluminum is not part of this group buy.
Bluzie
Bluzie's picture
Last seen: 8 hours 2 min ago
I send my Proto4 to my friend Andreas for beamshots.
Beamshots from Andreas
Thank you Andreas for your great work. Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 1 hour 43 min ago
Bluzie wrote:
I send my Proto4 to my friend Andreas for beamshots. Beamshots from Andreas
Thanks Bluzie and Andreas! It surely shows how the beam looks like, and i’m liking it Wink
BTW, that is with a 10508 Carclo, not the originally intended 10511 which will give a different beam with more hotspot, not so wide!
I do like it this way too, though as there are no beam artifacts Wink
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
JasonWW
JasonWW's picture
Wow, the gray anodization has a bit more blue in it than I realized.
Maybe these pictures were taken under a bright light. (Probably, maybe it’s due to a certain temperature of light that adds a blue tint)
tatasal
Perhaps the blueish tint is most probably the result of lighting (which affect the tint of the gray finish) when the photos were taken.
I have posted this photo elsewhere, and as an example of that effect, to show the change of gray to blueish, of the same light and time of photo-taking ( the right photo is the real gray finish of the Avaritia NA40SE) are the photos below:
More photos from this thread: HERE
Henk4U2
Henk4U2's picture
Last seen: 4 hours 28 min ago
Certainly not being the best person to brag about his photographic skills,
but I think that every person involved has shown us a photo with a different color of ano.
And I can’t imagine that LT fills a fresh bath of ano for every copy they send.
Is it possible to send one of the last specimen to a professional photographer, like DBCustom?
Or is it advisable to publish only photo’s of the FW3A in the company of well known lights?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
teacher
teacher's picture
I have posted this photo elsewhere, and as an example of that effect, to show the change of gray to blueish, of the same light and time of photo-taking (the right photo is the real gray finish of the Avaritia NA40SE) are the photos below:
/\ .. THIS .. /\
Agreed, thanks tatasal. . Thumbs Up
JasonWW
JasonWW's picture
They don’t do this themselves. It’s outsourced, afaik.
The exact color doesn’t matter to me. They all look good. Party
teacher
teacher's picture
Amen!! . Thumbs Up . Beer Beer
mortuus
mortuus's picture
Last seen: 6 hours 18 min ago
yes i agree with others all colors so far looks good.
...where Frugal meets with Flashlight!
coherent-rambling
Last seen: 1 month 1 week ago
Regarding emitter options: I’d actually prefer SST-20 over LH351D in this light. In fact, I’ll be installing some regardless. I know that means my vote shouldn’t count for much, but at least consider my reasoning.
It’s true that the SST-20 are dimmer than either the LH351D or the XP-L HI, and almost certainly have worse tint than the XP-L HI. However, let’s not get bogged down with comparisons to the XP-L HI since that’s an excellent choice and is getting produced either way. And the SST-20 isn’t going to have significantly worse tint than the LH351D; they’re both known to have fairly green binning on average if you don’t shop carefully.
The LH351D is a much floodier emitter than theSST-20 (which throws more like the XP-L HI), and in an already-floody 20mm triple TIR it’s going to be wasteful. You’re going to need to run a higher brightness level to light up a particular distance away. The SST-20 is much less efficient in an integrating sphere, but especially in a ramping light you aren’t going to ramp up to the same number of lumens on both options and then complain about how much hotter the SST-20 is getting – you’re going to ramp to the same number of lux on a particular target, because that’s the brightness you can perceive. And the SST-20 will be using less power than the LH351D to get there, not more.
If you care mostly about tint and efficiency, the XP-L HI is still your choice. But if you’re concerned more with CRI (especially R9), in actual use the SST-20 is a great option. I’ve got them in my Emisar D4 and their tight beam makes the light far more useful than the numbers would suggest. And, for a back-to-back comparison, I pulled the SST-20 out of my D4S and installed LH351D’s, because in that larger head they were too focused.
TheOnlyDocc
TheOnlyDocc's picture
I like the beamshots with the 10508 Carclo a lot. I will mostly use this light to light up thing close distance. So a very evenly floody beam would be nice.
So i hope they can get the LH351D. And i will most likely try to change the optic to a 10508 or something similar.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
maukka
maukka's picture
Last seen: 10 hours 13 sec ago
Here’s a calibrated photo of the FW3A. Used the X-rite colorchecker passport to generate a .dcp color correction profile for the Viltrox LED panel and Panasonic DMC-GM1 mirrorless SLR. It’s not as blue as the previous photo would suggest. Very slight bluish shift on the grey.
teacher
teacher's picture
Thanks maukka, nice work & pictures!! . Thumbs Up . Beer
Henk4U2
Henk4U2's picture
Of all the 50 shades of grey, this is a particular nice one!
Thanks maukka Thumbs Up
