What did you mod today?
Turned my franken-Astrolux E02 into a triple. (My first triple! How many years am I behind?) The e-switch was bouncy and the old Anduril had a few kinks that needed fixing so it was time for an overhaul.
The driver is basically the same as before, though this time I made use of the FET footprint of the L4P MCPCB. 3 channels, 1+2 [7135] + 7136 for “Turbo” (a moderate 3 amps).
3x 5000k LH351C (edit: C, not D!) 80CRI in a Carclo 10507. The MCPCB plus the optics’ legs had to be cut down to 18mm for everything to fit. A 10g copper slug sits in the head.
This time I got the “good” 7135s (the Nanjing ones) and the lowest flicker-free level in Anduril is 1. (I also added 10k pull-downs on all 3 channels, that may have helped too.)
Current on “moon” is 1.1mA, quiescent current is 0.25µA (down from 2.4mA / 15µA). (Thanks Toykeeper for all the good work! :beer: )
Yes the 7136 is a bit iffy. It doesn’t like PWM at all due to its soft-start (I only use it for turbo anyways), specs from different mfr’s are all over the place etc etc. I wouldn’t recommend it, it gives you headaches.
There’s one red AUX LED for map reading etc. under the optics but something went horribly wrong and I sure as hell won’t desolder every wire again just to get into the driver compartment… maybe next time.
Flashing… tweaking…flashing…
Can’t complain about the beam. The only visible artifact is the petals in the periphery but otherwise it’s very clean. This is @1m from the wall.
If I wanted this to be ultra-compact I’d go back to the 18350 tube but I feel the reduction in capacity isn’t worth it. Plus it just doesn’t feel right in the hand, the 18650 does (and it’s only 105mm long anyways.)
^ Damn…… Nice Job! :+1:
Very nice, never bought an E01 because of the UI, but I sure like the size and looks!
Currently working on giving an unreliable crelant v4a a new life. 2s2p 14500, 17mm 2s ta narsil driver from lexel, and 5000k Q0 mt-g2 from intl-outdoor when they were bargain priced. Something to work on while waiting for new reflectors from fasttech and replacement emitter for the L6 from banggood. Will post photos in a build thread in the near future.
A brain fart caused me to think I’d soldered to GND when I hadn’t. So the AUX LED is working now.
This is with a cheap chinese red one, probably not too efficient, pulls about 1.2mA total (1k5 resistor). Due to its size it sits somewhat behind the lens (and quite a bit of light is lost internally). I’ll fix this when I find a better LED.
EDIT: found a suitable 0603 LED, it now sits on a little stem right in the middle, directly under the lens. Current draw on “low” is ~55µA, on “high” it’s ~1.2mA.
A 2-die (series) red one would be ideal for this but I don’t think there are any. I think even on low it’s useful with dark-adapted vision, I’ll have to wait until tonight to find out. Pics below.
Low:
High:
I got away with a single-sided driver btw.
Yup once one gets rid of its original innards it’s a nice and very EDC-able little light. It takes all sorts of reflectors and optics due to the screw-on bezel, a few mm +/- don’t matter, very flexible. This one will live a long life I’m pretty sure.
OK, I can confirm. 56 microamps is enough for reading a newspaper in total darkness.
(Although every grandma will tell you “don’t do that, you’ll go blind”)
Ummmm, no. Not going there…
Ohhhhhhhh, suddenly the penny mod i’ve seen mentioned makes sense! It’s not a UK penny… :person_facepalming:
Yeah, i know, a newspaper in this day and age…
Yeah, that’s not where he is not going
Finally getting back into modding.
First two mods:
1) Thrunite TH20 Headlamp, change LED to 219C 3500K 90 CRI.
Loving this headlamp now. So much more pleasant and calming than stock LED with wonderful color rendering.
2) Eagletac M30LC2-C, changed XP-G2 70 CRI Leds to Luminus SST-20 3500K 95 CRI Leds.
There is a noticeable drop in output with the new LEDs. The light out throws my Zebralight SC600w MK III Hi by a small but still noticeable amount. The center intensity is higher than the Zebralight, but the spot is much narrower too. Its my first high CRI “thrower” and I am very impressed by the color rendering of these LEDs. Its refreshing to see colors pop from a distance. It makes reds/browns pop much more than the 3500K Nichia 219C above. The best part about this light is that it maintains the highest level without overheating at all, and its fully regulated. My guess is that it now outputs about 750 lumens, but this is purely a guess based on my perception of other lights. The spill is quite dim compared to the main spot so its very good at not blowing out your night vision so you can focus on the center spot in the distance. I am curious to see how an XP-L Hi 80 CRI 4000K Led would do in this light, but sourcing these seems expensive.
Modified TomE and TK’s RampingIOS to run on the new attiny412 (and in single-channel mode). Loaded it up on my D25 headlamp. The UI is so much better now (vs the D25’s original UI)! Full details in this post.
You say that (“the UI is so much better now!”) as if there were something wrong with ToyKeepers UI to begin with.
Edit: Ah, I am going to assume you mean the light is better with Anduril Ramping IOS than with the OEM UI… sometimes I’m so dense. :person_facepalming:
Yup, I definitely meant “better than the D25’s stock UI”. Thanks Dale, I just added clarification.
gChart that’s an awesome mod :+1:
Did a emitter reflow on a Coast HP1 today.
I have two of them, given as gifts some time ago. And they rarely see any action.
Mostly because they have a horrible cold white blue 6000K+ish emitter.
And they are zoomies, which I’m not a fan of.
Now, given my recent “level up” into the world of reflowing, why not give one of them a proper emitter.
I had a SST-20 J2 JC1 2700K CRI95 laying around, mostly to test how Luminus’ take on a 2700K performed.
swip swap and the SST20 was reflowed to the tiny custom copper PCB the HP1 uses
The PCB is being pressed down to the shelf via the plastic “thing”
Comparison GIF
Sequence:
0: D4 219B 4500K
1: HP1 2700K flood
2: HP1 6000K flood
3: HP1 2700K throw
4: HP1 6000K throw
2700K is of course a novelty, its very very warm. But at least it’s better than the CW, and now has 95CRI :smiley:
Hacked together a 4.15$ C8 and an e-switch TC driver running Anduril. It kind of works, still has issues and I’m not even sure if this is a heresy or not.
Interesting. Pics or additional details? How do you have it wired up?
A C8F host is so cheap, easier to go with a light already setup for e-switch. Just wish they made a 1 LED version of the C8F host. Would be a cheap mod for sure.
Only a driver pic so far, it’s still quite a mess. I’ll do a writeup if I get this to work reliably.
The setup basically is this: there’s a ~100R bypass resistor in the head parallel to the LED so that the body functions as the positive pole (when the LED is off). In the tail, there’s a 47µ filter cap behind a diode. You rely on PWM to keep this cap charged, this means you have to stay below a certain duty cycle. The rest is pretty much a standard ATtiny 85 driver 1+n+FET(w/shunt).
I’m still having issues at the top of the ramp (µC resets) so my max duty cycle is probably too high. I also suspect 18kHz PWM might cause instability. May be a sketchy diode or too strong pulldowns, maybe the springs need bypassing. Maybe bad Anduril config, it sometimes steps down like it’s thermal throttling but I’ve got thermal management disabled (and thus can’t even re-calibrate the temperature.) :question:
I pretty much had it stable when running from a lab supply so the error can’t be that far.
This won’t win any beauty contests…
Yes but where’s the fun? It already exists, and anyone can have it.
