*BLF LT1 Lantern Project) (updated Nov,17,2020)
Ok that works for me…Thanks!
Done deal!
My pleasure….and it gives me something to do since I don’t work anymore :stuck_out_tongue:
I can’t find my name on the List!?
You are at 514 and 1239
Just for info, is there a V2 in the works and if so what would be different?
What are the ca. dimensions of the lantern?
So people can search for transport pouches
I like this one for the
BOSE SOUNDLINK REVOLVE BLUETOOTH SPEAKER
15,2 cm x 8,2 cm x 8,2 cm (HxBxT)
Has a little extra space for the charger. Is even tapered, but I don’t know if it fits. (probably a bit to wide)
US $12 New PU Travel Case For Bose Soundlink Revolve Case EVA Carry Protective Speaker Box Pouch Cover Extra Space For Plug & Cables
https://m.aliexpress.com/item/32853843814.html
Or this
https://m.aliexpress.com/item/32956334808.html
There is a V1 in the works, that’s for sure :slight_smile:
We can have ideas and wishes for a V2, but it is up to Sofirn to think it feasable enough to actually make it, so it could happen but I would not bet on it at this point.
With some of the ideas for the v2 I have seen pop-up I sure hope they do though. Would probably end up with a lantern or two more.
I’m interested in this lantern. Maybe two depending on price.
I found myself on the list, #672, but I think I’m miss understanding the name check. It’s definitely correct, but I can’t click my name and go to my profile.
The name check is just to verify that it’s correct in my database as I don’t have any way to join my tables to SB’s server. When the lanterns are ready for purchase I will create the pm lists on my end that SB will execute on his end to send out the actual pm’s. If the name is incorrect in my table then that person won’t receive a pm.
Clicking on your name on the list won’t take you anywhere and is solely intended as a visual check. It’s a one-time only verification so since you saw that it’s right then you don’t have to do it again.
Btw the Entry number on my lists do not necessarily correspond to the one’s that DBSAR show for minor technical reasons (although 99% are the same). But the order they were loaded into his and mine are exactly the same for anyone who is curious or worried about that.
Perfect, thank you!
Is it too late to be added SigShooter?
Have the feeling this lantern will be one of those legends that keeps getting refined. Exciting project.
Not at all. I already entered you into my database for 2 per your prior post. You will see them next Sunday night when the updated lists are published.
And welcome to BLF :slight_smile:
Thanks
Thanks SigShooter. Learned about this project on FB, Flashlight Fanatics group. Long time lurker here.
i didn’t know about that group on FB, maybe i should apply to join.
You should. Just keep in mind they’re quite serious about the rules. I don’t think it’s that big of a deal, though. If you don’t like/agree with something move along and you’ll be fine.
I’m interested in the lantern but this is very much dependent on price, any possible range?
