I like this one for the
BOSE SOUNDLINK REVOLVE BLUETOOTH SPEAKER
15,2 cm x 8,2 cm x 8,2 cm (HxBxT)
Has a little extra space for the charger. Is even tapered, but I don’t know if it fits. (probably a bit to wide)
US $12 New PU Travel Case For Bose Soundlink Revolve Case EVA Carry Protective Speaker Box Pouch Cover Extra Space For Plug & Cables https://m.aliexpress.com/item/32853843814.html
There is a V1 in the works, that’s for sure
We can have ideas and wishes for a V2, but it is up to Sofirn to think it feasable enough to actually make it, so it could happen but I would not bet on it at this point.
I found myself on the list, #672, but I think I’m miss understanding the name check. It’s definitely correct, but I can’t click my name and go to my profile.
The name check is just to verify that it’s correct in my database as I don’t have any way to join my tables to SB’s server. When the lanterns are ready for purchase I will create the pm lists on my end that SB will execute on his end to send out the actual pm’s. If the name is incorrect in my table then that person won’t receive a pm.
Clicking on your name on the list won’t take you anywhere and is solely intended as a visual check. It’s a one-time only verification so since you saw that it’s right then you don’t have to do it again.
Btw the Entry number on my lists do not necessarily correspond to the one’s that DBSAR show for minor technical reasons (although 99% are the same). But the order they were loaded into his and mine are exactly the same for anyone who is curious or worried about that.
Not at all. I already entered you into my database for 2 per your prior post. You will see them next Sunday night when the updated lists are published.
You should. Just keep in mind they’re quite serious about the rules. I don’t think it’s that big of a deal, though. If you don’t like/agree with something move along and you’ll be fine.
I’m #685 and haven’t seen any PMs yet. Does anyone have any idea what range on the list is being served now? Also, what is the price? I haven’t seen any posts with pricing and I can’t search all of the pages to find it. Thanks
