The name check is just to verify that it’s correct in my database as I don’t have any way to join my tables to SB’s server. When the lanterns are ready for purchase I will create the pm lists on my end that SB will execute on his end to send out the actual pm’s. If the name is incorrect in my table then that person won’t receive a pm.
Clicking on your name on the list won’t take you anywhere and is solely intended as a visual check. It’s a one-time only verification so since you saw that it’s right then you don’t have to do it again.
Btw the Entry number on my lists do not necessarily correspond to the one’s that DBSAR show for minor technical reasons (although 99% are the same). But the order they were loaded into his and mine are exactly the same for anyone who is curious or worried about that.
Not at all. I already entered you into my database for 2 per your prior post. You will see them next Sunday night when the updated lists are published.
You should. Just keep in mind they’re quite serious about the rules. I don’t think it’s that big of a deal, though. If you don’t like/agree with something move along and you’ll be fine.
I’m #685 and haven’t seen any PMs yet. Does anyone have any idea what range on the list is being served now? Also, what is the price? I haven’t seen any posts with pricing and I can’t search all of the pages to find it. Thanks
It does matter actually, and it matters to many. Money always matters. I had 30-40 in my memory as well, and that is what I think is ok to spend on a lantern. I hope Sofirn too.
Costs in sourcing the high CRI good LEDs, etc. Once the test samples are built and if they test good, then we will know the production prices, ( for both the group buy & retail MSRP.
I think we should do our best to keep the cost down on the V1, learn from it and improve on V2. A $15 increase is 50% more than what was earlier discussed. If Sofirn sees we are discussing $55 they might assume they can charge more to produce it. It could turn into a money grab and it would end up not being the ‘Budget’ lantern this started off as and interest would probably fade. Im glad I have my four Zanflare T1s and they were only $16/ea.
