I paid $16.72 for two TG06S flashlight last Nov from seller autocaredepot (now doing business as trac8894)), and they turned out to be poor quality fakes:
They had the modes: High, Medium, Low, Strobe and SOS - INLINE. Whereas, the modes in a real TG06S have the modes High, Med, Low, MoonLight; and double tap to access Strobe.
There should have been NO memory versus next-mode memory found with these.
These flashlights were not even close to 500 lumens in High as with a real TG06S, and they have a cool white emitter (with a greenish tint) versus warm white, as they should.
Grinding occurred while screwing head to body.
But appearance wise, they were similar to the real thing.
Got refunded for one while keeping both, and they are now in my give-away-to-a-stranger collection.
Yeah, the muggle won’t know any better if the light’s Angry Blue or Hateful Purple, so who cares? :laughing:
I already got the 4C XM-L[2?] and 1.4A driver lined up, just gotta shave the driver about 2mm smaller to fit the pill, and hope I don’t file through any necessary vias and break something. “Dumb” driver, just 7135s and a diode.
Through an aspheric, the tint should be that beautiful warm-sunlight color as through a TIR. Oh, it’ll probably cook itself if left on too long, so I’m going to have to backfill the gaps with… something.
I paid around 5 AUD for a “TG06” on eBay recently and while it looked very convincing (including the packaging) it had the terrible five-mode driver with inline strobes and next mode memory. For the price the build quality is nice, but I wouldn’t give a light with next mode memory to my worst enemy.
I just pulled the trigger and purchased three of the INLAND 1W R22 LED flashlights based on this information. Even though shipping was a bit high, I am anxious to check them out. Off topic, but I remember that your recommendation of the NiteFox UW360 (in a previous thread) was pure gold. A little expensive also from Amazon, but well worth the cost. Thanks!
Edit: Are the "LFP" batteries you mention above lithium primaries? Thanks!
3.2V rechargeables. Flat voltage curve over most of its SOC, like NiCd, used quite often nowadays in solar walkway lights (directly powers the dinky little LED vs needing a separate boost converter from a NiMH cell).
I disagree. I have given away a bunch, and they work, and are bright.
Try one marked EnjoyDeal.
Few care about tint. I have not noticed. Most people dont use flashlights for flashlights sake, but when needed want one that turns on/off and is reliable. I have found these fit the billl.I am not dure of the output but estimate 80 lmn and maybe more.
The OP asked for a light priced around $5. As usual a lot of folks here don’t do as requested, but recommend one that is 3 times that amount. That is OK, but why not also find one at the requested price?
The only problem I have notices with most of those light is that the threads are too few and shallow.
Jerry
I think you will be fine with these, very bright and throwy with a 14500, the only issue I had with mine (supposedly ‘Titanium’ version) of this same light, is the UI tail switch being very spongy.
Its weird by the button requires a deeper press than my thumb can manage.
Shallow indeed, but pretty impressive light considering what you are getting for $2 today. It may not survive long but time will tell. I compared the brightness and beam to several other AAA’s I own and estimate it to be at least 120 lumens which is brighter than almost any flashlight people might have had 10 short years ago.
