Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17400 posts / 0 new
djozz
djozz's picture
Last seen: 3 hours 15 min ago
The first 500 Q8’s (or was it the first 150?) had quality issues with the switch leds. The later batches had better quality switch led boards. Many people with a failed switch received a new switch-board at the time. But I’m not surprised if switch leds from the first 500 that did work, fail at some later point. So it is good that Sofirn sells the improved board.
But it is also possible that in some cases people claiming failing switch leds in fact had switched them off without knowing.
Tom E
Tom E's picture
Last seen: 1 day 3 hours ago
+1 - forgot there were quality issues in the early batch... Thanx djozz! I'm forgetting more than I remember, or that I forget - I forget which   innocent
shirnask
shirnask's picture
Last seen: 2 sec ago
Yes, I had 3 of the first batch. One switch had bad leds on arrival and a second one failed more than 6 months later
immortal--
Hey, if I buy BLF Q8 can I use my XTAR VC2S charger or I need to buy 4 slots charger? I’ll buy 4 new cells.
djozz
djozz's picture
There’s no problem charging them in two batches. The parallel configuration in the Q8 does not require perfect charge matching.
It is always a good idea of course to keep the 4 cells together so that they receive the same wear over time.
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 22 hours ago
The charge matching is one of the big reasons I like the SP36. Having a built-in charger allows me to charge all the cells at once, to exactly the same level… even if that level isn’t 4.20V. Otherwise it’s kind of hard to do a partial charge on a married set of cells.
But if you’re charging until full, there should be no problem charging two cells then charging the other two.
JasonWW
JasonWW's picture
Last seen: 5 hours 41 min ago
How many are considering adding the new 3v xhp50.2 on a LED4POWER mcpcb?
The Q8 seems like a great choice for this new led.
Click this to go to signature links.
Alexium
How many lumens would those give out in a Q8?
MTE C3-907 -> Convoy C8 -> Convoy S2+ -> BLF Q8 -> Sofirn SP36 -> Somebody please make me stop!
djozz
djozz's picture
Not considering it, it is going to happen the day the leds come in (will take a while, they come via the CRX group buy). Lumens? About 12K
cabfrank
Last seen: 1 hour 13 min ago
Wow that is a huge difference.
Barry0892
Barry0892's picture
Last seen: 16 hours 16 sec ago
WhatsApp: +8615773183209
Facebook: https://www.facebook.com/barry.lee.984991 (my account is disabled cry)
WalkIntoTheLight
Last seen: 6 hours 49 min ago
Wow, those 3v 50.2’s must have a really low forward voltage. Will 30Q cells be able to handle 12k lumens, without sagging too much?
SomeAussie
Last seen: 4 months 1 week ago
Hi, I’m having an issue with my BLF Q8 and I’m trying to find out if there’s anything I can do to fix it or if I have to return it. I’m not technical with torches, but I’ve been reading posts, manuals and guides to try to figure this out.
When ramping up, it stops at a fairly lowly level. If I continue to hold the button, it still double flashes after the amount of time it would normally take to reach full brightness. When ramping back down from “full” brightness, there is a delay until it reaches its limited brightness level and then decreases to moonlight as normal. If I stop ramping while it is below its limit, the button flashes only once. If I stop ramping while it is above its limit, it flashes twice. This makes me think the FET channel is not working.
I’ve tried doing a factory reset from the version check mode. It does the rapid flash to confirm reset has occurred but it continues with the same behaviour.
It was working fine yesterday. This issue started after doing the latest recharge of the batteries. I’ve used it on and off over the last 6 months since I bought it with no issues. I bought the batteries brand new at the same time (Samsung 30Q 18650 button tops).
The only other weird issue I’ve found is the battery indicator seems to be reading low. The freshly charged batteries each read 4.2V in my charger (XTAR VC4), but in the torch it indicates only 3.1V.
Any suggestions on what’s wrong and what I could do to fix it? Or should I just return it to where I bought it? Or should I be asking elsewhere?
Thanks
JasonWW
JasonWW's picture
Thanks
It does sound like the FET has stopped working and your only running on the single 7135, so maybe 150 lumen max. A video to show what your describing would help, but I think I understand you.
You can try a return or warranty replacement, but I don’t know if they will do anything since it worked fine for 6 months.
With a bad FET, you can buy a new FET for a few dollars, but you need hot air to swap it.
You can also buy a complete new driver here for about $10 usd. You will need a soldering iron for the led wires.
I’m curious if others also think it’s the FET. The battery thing is strange. With fully charged cells it might read 4.1v, but 3.1 is strange.
djozz
djozz's picture
dunno about the battery voltage readout, but the ramping behaviour sounds efinately like the FET not working, or the trace from MCU to FET not making contact. First try could be soldering some extra solder to the legs of the FET and perhaps the leg of the MCU that goes to the FET-gate. That tests a possible bad solder joint that originated over time.
Shur
Last seen: 4 days 1 hour ago
Check the batteries with a DMM (digital multi meter)?
I’d first try and eliminate all of the possibilities that don’t require soldering myself
I don’t actually think the batteries will be the problem but it’s best to be sure
Calaveras
Also check the battery control contact with the brass ring. I had a set of batteries that I used and only one worked. I rearranged the batteries and tightened fully they all were in contact, it worked fine.
WalkIntoTheLight
I wouldn’t bother messing with the FET or getting a new one. The incorrect voltage readout indicates there’s more to the problem than just a bad FET. Get a whole new driver, or new light.
Mike89
Last seen: 2 min 18 sec ago
What is the difference between this and the Sofirn Q8?
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 1 min ago
The BLF Q8 has a more neutral color temp and more lumens, in exchange for less throw.
The Sofirn Q8 throws farther due to its domeless LED emitters.
Calaveras
@mike89
short answer is:
The BLF version uses 5000K neutral white emitters. made by -Lumintop -“Thorfire”
the Sofirn uses ~6000K cool white emitters. made by Sofirn.
Corrected. the green “T” button looks at me every night… Facepalm
djozz
djozz's picture
Correction: the BLF version is made by Sofirn also, under the name of Thorfire.
JasonWW
JasonWW's picture
The emitters. Thorfire Q8 uses xpl NW, Sofirn Q8 uses xpl-hi CW. The Sofirn Q8 has a smaller hot spot and more throw.
LightMan541
Was #1469 pre-order.
My beacon switch led stopped working. Any fix or replacement parts for it?
shirnask
shirnask's picture
SomeAussie
Thanks
It took me a long time to get around to it, but I bought a new driver and that fixed it. Thanks for your help!
JasonWW
JasonWW's picture
Thumbs Up
Does it say the correct voltage now?
SomeAussie
JasonWW wrote:
Thumbs Up
Yeah that’s fixed too!
Sordoslux
I got my BLF Q8 in the original group buy, and it has seen some use from time to time. Mostly camping and emergency light at home. I see there’s now Anduril firmware for it. Is it worth learning how to flash / getting the hardware to do it?
JasonWW
JasonWW's picture
Do you like Anduril? It has it’s pros and cons. If it has a feature you really want then it might be worth it.
