ALL THINGS BUDGET KNIVES
The 7582 does bare quite the resemblance to the ProTech TR-4, yes.
Like I said, if Ganzo did a Calmigo copy I’d be all about that.
TwoSun :smiley:
TS57, TS111, TS20:
TS20:
TS17-G10:
TwoSun knives :+1:
After reviewing it I decided to refine my “Rubicon” a bit. So I reprofiled the edge after adding a sharpening notch to the blade then I smoothed the edges of the backspacer and the G10 scales. I also chamfered the edges of the opening hole.
Excellent tune-up. I am very pleased with this blade and can’t believe the fine quality at such a bargain price.
Thanks for the great photos and review.
Are there any budget knives with bushing pivots? Like the Sebenza 21? A bushing pivot has an additional bushing that the pivot tightens against, instead of the blade. So you can tighten it without increasing friction in the pivot.
@ Man Without Shadow …. What knife is that please? Link appreciated if you have one. :slight_smile:
You’re welcome! At this price there’s nothing to complain about. :slight_smile:
:+1:
I have the G10 version of this Zieba style front flipper:
A new Brother 1609g knife is listed on gearbest.
I don't know what Spyderco model it is a look-alike of, if any.
https://www.gearbest.com/with-lock-folding-knives/pp_009863250916.html
It reminds me of the D’ALLARA 3.
Hey,
I have this knife too, and it’s very hard to open!
I think it’s because of the very small flipper tab.
Does yours have the same issue?
Hello
I’ve had the same issue but I was reading about it before I’ve bought it on the bay for $43
The trick is to keep your fingers away from the lockbar. That happens with some framelock folders, the SRM 9103/4 is such an example.
When the finger is out of the way mine flips like a dream, even better after I disassembled it and cleaned out the grease.
The biggest issue I have with it is the clip though, it should be closer to the back of the handle instead if laying over the framelock relief.
This way it’s a real seam catcher which makes it difficult to draw. I’ve sanded away a bit but afterwards I couldn’t get such a nice anodisation.
Maybe it will get a rock pattern someday, right after my SRM 813 has its carbon fiber scale :wink:
It’s a replica of replica of Michael Zieba Gentleman’s G-2 knife :slight_smile: With very soft steel.
Original: http://forthenrycustomknives.com/product/michael-zieba-g-2-gentlemans-zdp-189-front-flipper-skyline/
I have replica from CH Outdoors, named as ZiebR (Zieba Replica) with HSS steel 1.3343 (not ZDP 189, but so close), 62 HRC:
CH Outdoors 3504 D2 G10
CH Outdoors 3504 Titan Blue S35VN
Swap the blades
Thank you for the info MaksVasilev!! :+1: . Good looking knife & great pictures too.
TwoSun TS20 :slight_smile:
